WTB Early Notch rear window rubbers
Notch Nut - July 9th, 2007 at 07:38 PM
G'day.
I am wondering if anyone may know of the whereabouts of a decent window rubber seal for the Rear windscreen of an early notchback. (Melbourne would be ideal if possible for pick up but not exclusive or fussed either way).
Im also not after the Cal look either. Just after something of high quality that fits properly without too much hassle.
Any hints or info on brands or previous hassles with various types of rubber seals available welcome also.
Cheers.
- Adam
vw54 - July 10th, 2007 at 06:52 AM
I dont think you will find an origional screen rubber with the groove these days
It will have to be after market and you may have to use a different type of trim
Give Vintage a call 02-9789-1777 they may have an old stock, and do have the aftermarket version
Notch Nut - July 10th, 2007 at 09:41 AM
Cheers VW54:thumb
- Adam
matara - July 10th, 2007 at 11:26 AM
Got mine from Vintage Veedub in Sydney. Only place in the southern hemisphere that carried the one with the moulding groove.
Excellent fit and quality.
Rocket - July 10th, 2007 at 02:42 PM
I bought a rear Notch window rubber from Wolfsburg 1300370310 worth a try.
vw54 - July 10th, 2007 at 05:38 PM
Adam
Ive just checked with Vintage for you and they have some origional type rubbers available with the groove
Notch Nut - July 13th, 2007 at 10:26 PM
Thanks guys.
I'm gonna try Vintage on my day off Tuesday and see how I go.
Cheers.:yes:
Notch Nut - July 17th, 2007 at 10:38 AM
Just got off the phone to vintage. Most helpful and great price.:tu:
Now if only the rain would stop a bit so my car won't leak until then:duh
- Adam
vw54 - July 17th, 2007 at 06:41 PM
Cut the old rubber off with a Stanley knife both inside and outside so you get the glass out in one piece will save a lot of frustration
Notch Nut - July 17th, 2007 at 10:21 PM
Not to mention, saving the metal trim from distorting in shape so it can be re-used!:alien
jo_tas - July 17th, 2007 at 10:33 PM
Yeah... mine got distorted..
My panel beater put it in a place he reckoned would be really safe.. and it wasn't.. grr
vw54 - July 18th, 2007 at 06:54 AM
Jo Panel Beaters are like that LOL
Notch Have you fitted a window before ??? If not the fit the rubber to the glass then fit the trim onto the rubber then into the car yo will need a few mates as well to help n hold in the right place
I did it a few times trying to fit the trim to the rubber after the glass was in teh car IT DONT work that way
Notch Nut - July 18th, 2007 at 04:00 PM
I have only fitted my pop outs to my notch (with a broken wrist in plaster - I had nothing else to do while off work with an injury like that!:duh)
I am planning on getting O'brien glass to do the fitting. They come with a guarantee and plenty of that special sealant.
I am just removing the old rubbers/window & mouldings so as to avoid damage and do any clean up necessary once the window is removed.
Cheers for the advice:D
- Adam
empi - July 18th, 2007 at 07:15 PM
Ask empi Kg about rubbers,
Get 2x 135/145 tyres and then pop over Ad.
Ad
vw54 - July 19th, 2007 at 07:03 AM
NOOOOOOOOOOOOOOOOOOOOOOOOOoooooooo
Obriens Yuk
Is there a VW guy down your way that can do the job
If your body shell is clean and the drain holes are clear DONT use any sealant thats why the rubber is used
I luv fittings windows wish i was down yr way make sure they center the rubber on the glass it always looks ugly when the rubber join is in the wrong spot
Hutcho - July 19th, 2007 at 02:49 PM
Hi Adam,
I used VVWS rubbers for my front/back screens. Theyre VERY good. Im also echoing Daves post above...Dont use sealant!
Cheers,
Hucho.
Notch Nut - July 19th, 2007 at 09:28 PM
Ok. I won't use sealant nor fork out $$$ for O'brien etc.
That being the case, it looks like a beer drinking session interupted by the occasional bit of work on the dub with the usual suspects then....
Thanks for all your help and advice. It's so much more comforting than wondering if/how it could get botched up by my interferance.:spin:
- Adam
