[ Total Views: 957 | Total Replies: 6 | Thread Id: 100077 ]
Author: Subject:  S/F Heads & 48mm Webber kit
MemberRodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
posted on December 9th, 2012 at 05:14 PM
I have a reco set of ported Superflow heads that have 44mm x 37.5mm stainless valves and K 800 chevy springs . These are bored for a 94mm cylinder and have valve covers and match ported IDA intake manifolds . The manifolds have nitrous ports if required . I have a brand new set of 48mm IDA carbs and a CB hex bar linkage to complete the deal . The chambers measure 40 cc and are a complete bolt on deal . I would like to get $ 1100 for the heads and $ 1250 for the carbs and linkage . I would do a package deal for $ 2200 for the lot . These are located in Wollongong NSW and can be shipped anywhere , ROD , 02-42729920 .
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
MemberRodPenrose
Threads: 330
posted on December 9th, 2012 at 05:15 PM
MemberIan Bugden
A.k.a.: Ian Bugden
AKA - Bugs
Threads: 57
Location: The home of Pollies, Pyro and Porno - Canberra
Mood: Go Hard or go Home!!!
posted on December 12th, 2012 at 01:37 PM
Would you be able to run these on the street? I know they are not for a everyday driver, but limited use. I would prob run a comp ratio of between 9 and 10:1
Bugs
A good friend will come and bail you out of jail.....
But a true friend will be sitting next to you saying "Damm that was fun!!!"
Memberpetemart
Threads: 18
Theme: UltimaBB Pro Charcoal
posted on December 12th, 2012 at 04:29 PM
Bugs
I used to run a set of the older ARPM Superflows with no fins on my 1916 (then onto a 2165) daily driver that I rev'd to redline whenever I drove it.
I never had a problem with oil temprature around the streets and highway driving, but I ran a bigger type 4 cooler in the doghouse.
I have heard the superflows heads run a little hotter but I used to rebuild motors every few years to change combos, so I cant realy comment on longevity.
I bought the Berg adapters to run stock rocker covers as my ARPM covers used to come loose all the time and it made it cheaper to replace the rocker cover gaskets and a hell of a lot easier to do the valves.
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on December 12th, 2012 at 10:01 PM
Bugs
The heads have 40cc combustion chambers.......what size motor do you intend to build ?
posted on December 13th, 2012 at 07:21 AM
40cc chambers and Chevy springs......
MemberIan Bugden
A.k.a.: Ian Bugden
AKA - Bugs
Threads: 57
posted on December 14th, 2012 at 11:40 AM
I was thinking along the lines of a 2054, with that small of chamber I would have to run spacers to get the compression down. and prob run a fk8 or fk89 cam.
Bugs
Bugs
