[ Total Views: 1747 | Total Replies: 9 | Thread Id: 100301 ]
Author: Subject:  My 1600 tp blowing white smoke constantly
MemberDylanTheDubber
Threads: 173
posted on December 28th, 2012 at 05:38 PM
What could cause my bug to blow white smoke constantly?
Oil has only just been changed now long ago when motor was installed.
Stock motor apart from extractors.
From Dylan
MemberJVLRacing
Threads: 30
posted on December 28th, 2012 at 07:30 PM
From Dylan
u put new piston rings in?
posted on December 28th, 2012 at 08:00 PM
is it Auto??
Membercam070
posted on December 28th, 2012 at 08:32 PM
Checked your air/fuel mixture?
posted on December 28th, 2012 at 08:49 PM
Generally black smoke - fuel = too rich, blue smoke - oil = worn rings or valve guides, white smoke that disapates = water vapour, white smoke lingers = brake fluid (not applicable to a manual beetle)
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on December 28th, 2012 at 10:15 PM
Poor quality fuel from a servo had water in it?
(ô_!_/ô) (ô_!_/ô)
Threads: 173
posted on December 29th, 2012 at 04:55 AM
Cheers Guys, Possibly Had water Get in as it was parked outside for 2 days while i was away and it was raining pretty hard i heard and it has a sports air filter so water could have got in through the decklid as it only just starting doing it since i got back.
From Dylan
Threads: 173
posted on December 29th, 2012 at 04:58 AM
John,
No i haven't even looked underneath the head, i just bolted it all up and she went, and good compression too.
And Also guys it's a manual.
From Dylan
posted on December 29th, 2012 at 07:54 AM
I thought it was
black = rich
blue = oil
white = raw fuel
I have certainly seen "white" smoke when a motor starts after it has been flooded or a "dead" spark plug comes to life
Usually you will get a big cloud that disapates very quickly
Membergrumble
Mood: happy all the time
posted on December 29th, 2012 at 08:59 PM
Use it for a few kilometres Dylan,the engine has been standing for a while and may need to run it in again,sometimes the rings skip over a bit of surface rust on the cylinders and the oil will drain to the bottom of the cylinder giving a nice cloud of smoke on start up.Put an oil bath cleaner back on it. Cheers Les
[ Queries: 40 ] [ PHP: 15.5% - SQL: 84.5% ]
