| [ Total Views: 1162 | Total Replies: 7 | Thread Id: 100361 ] |
volk hogan
Threads: 17
Mood: chop chop
| posted on January 4th, 2013 at 02:21 PM |
dropped spindles
howdy,
I've just pieced together my dropped and narrowed beam for my oval. I've used a 60's king/link pin beam. I purchased dropped spindles from the
states. the stub axles are significantly shorter then standard axles. there is not enough room to put on the 2 retaining nuts.
will this problem be fixed by using the latter model wheel bearings?
if so what am i after?
if not what's going on?
thanks...
ragged
A.k.a.: David
Just ask if you need HELP!
Threads: 46
| posted on January 4th, 2013 at 03:40 PM |
I think I can help you out. The later style are a different thread but I do have a set somewhere that has the early style thread with the later style
pinch bolt.
Dave
volk hogan
Threads: 17
Mood: chop chop
| posted on January 4th, 2013 at 04:54 PM |
thanks dave, the thread is correct. the issue seems that the hub will not go all the way on. that's why i'm questioning the wheel bearing issue?
ragged
A.k.a.: David
Threads: 46
| posted on January 4th, 2013 at 04:58 PM |
Just sent PM with contact details. It's too hot to do anything else so give me a call and we can discuss.
Dave
volk hogan
Threads: 17
Mood: chop chop
| posted on January 4th, 2013 at 05:37 PM |
great thanks dave, i'll prob give you a call tomorrow.
vwo60
Threads: 71
Mood: good
| posted on January 5th, 2013 at 08:04 AM |
are they a disc brake spindle for the link pin front end, if so they use the ball joint bearings.
AndrewB
Threads: 19
Mood: arghhbjfhbejrhfebf
| posted on January 5th, 2013 at 09:02 PM |
or you have left a spacer on and need to remove it?
volk hogan
Threads: 17
Mood: chop chop
| posted on January 15th, 2013 at 06:26 PM |
Cheers Dave & Andrew,
That's what i had done, The dropped spindles did not require the spacers.
