[ Total Views: 626 | Total Replies: 4 | Thread Id: 100372 ]
Author: Subject:  Brake problem
Membersplitbus
Threads: 12
posted on January 5th, 2013 at 01:25 PM
Brake problem
Coming back from the hardware today, put the brakes on but nothing, the peddle was solid as if it had stuck on something, so I got home alright to check it out, if you pump the brakes a few times it locks hard, can't push the brake peddle down and no brakes, let it relax and they work fine, it's only if you pump them a few times that it locks, anybody else had this problem or know what would cause it, (standard brake system 1963 bus)
Cheers, Mike
| o*/o | 55 split screen
I don't have a bucket list, I have a f^%k it list a mile long
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on January 5th, 2013 at 01:41 PM
sounds like air in the system mate.
the chaos project - click me
Memberian.mezz
Threads: 280
posted on January 5th, 2013 at 01:48 PM
is it 4 wheel drum??
what your saying is what happens when you have a booster fail on a newer bus with dics on front ??.
:lol::crazy::lol::crazy::lol:
MemberCamo
A.k.a.: Kev
Threads: 209
posted on January 5th, 2013 at 02:00 PM
As Ian said, pending on what type car and year you are talking about.
If an old well worn car, you can (but not common) wear the brake master cylinder bore and this causes a lip. Then when you apply the brake the piston kicks a little sideways in the cylinder and can catch on this lip and this stops the piston travel. Feels like a hard pedal, but not really applying pressure to the brake fluid with the master cylinder.
If it is like this, you will need to bore it out or buy a new master cylinder.
Kev
posted on January 5th, 2013 at 07:42 PM
Yikes.. a weird one..
if its an old master cylinder [like Kevin says]
better to replace with a new one...
with twin brake system.. [if its not already]
