[ Total Views: 1843 | Total Replies: 15 | Thread Id: 100470 ]
Author: Subject:  COOLING PROBLEMS
Memberkarmad
posted on January 13th, 2013 at 11:58 PM
COOLING PROBLEMS
How long does it normally take for the thermostat to open if ur car is sitting running in your drive way Ej20 motor. my bug was running for 15 minutes and the stat hadnt opened but the fans came on . is this normal?
it has a new stat in it :smt017
Super AdministratorMISS VDUB
A.k.a.: Ash
Mrs KOMBIBOB
Threads: 96
Mood: Low down and Dirty
posted on January 14th, 2013 at 11:47 AM
How long is a piece of string sort of question? What was the temp gauge reading? How hot was the weather outside? Were you parked on a surface radiating excessive heat etc etc etc.... All factors...
1962 Baja Beetle: "Peanut"
1968 Porsche 912 SWB: "Pip"
1972 Kombi Snail: "The Snail"
2016 Scirocco R: "Rocco"
posted on January 14th, 2013 at 05:27 PM
Is this a new installation?
What have you done with your heater circuit?
What sort of motor is it? Turbo or NA?
Any new installation you need to be feeling the top and bottom pipes at the front & the back for heat transfer.
Fans have come on because the motor is hot even though the radiator hasn't been heated. Tell us more and maybe we can help.
Memberian.mezz
Threads: 280
posted on January 15th, 2013 at 06:03 PM
did you put it in the right way around??
Normally takes a long time for my fans to come on .
are your fans operated by ecu ??
Fans shouldn't come on until all the cooling system is very hot when up to operating temp, shouldn't be able to hold any of the hoses with your hand as hot.
:lol::crazy::lol::crazy::lol:
Memberkarmad
posted on January 20th, 2013 at 04:48 AM
This is my cooling system, can anyone see anythig wrong?
http://i1196.photobucket.com/albums/aa412/karmad76/Raddiagram_zps596876b3.jpg
Member11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on January 20th, 2013 at 07:06 AM
Where's the heater? The subaru's use flow through the heater to open your thermostat
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Memberkarmad
posted on January 20th, 2013 at 07:53 AM
Hi and thanks for replying to me. Joel on here on here has never ran a heater with no problems . what do you think of my layout ?
posted on January 20th, 2013 at 08:46 AM
Hi Graham,
still giving you grief?
Might pay to test the thermostat in a jug of boiling water just make sure it is opening.
If that tests out ok the hot return to the waterpump from your headertank is the problem, either an air lock or a kinked hose.
You don't need a heater, just a loop on the heater circuit which you have.
Memberkarmad
posted on January 20th, 2013 at 10:06 AM
Cheers mate, always saving my ass it means alot . i still havent driven the car since the new motor went in but the stat still doesn't open after maybe 15 minutes but the fans kick in . i have a new thermostat in it that i cooked before installing so i wouldn't think it was that but will check again and i will check all pipes for kinks as well . how are things with you mate?
posted on January 20th, 2013 at 08:12 PM
Ah all good just keeping busy with the usual crap.
just sitting idling around it should be upto to temp in under 10 mins.
does take a while for the thermostat to open right up becuase there is so much coolant in the system.
Your fans coming on is a good sign the stat is not opening, I bet the rad would still be cold?
posted on January 20th, 2013 at 09:25 PM
If your fans are ECU controlled they will come on the if the coolant is hot in the coolant manifold, you may not even have flow through the radiator.
Fans coming on with a cool radaitor is a bad sign.
Have got all the air out of the system?
MemberGracey
Threads: 17
Mood: Itchy
posted on January 20th, 2013 at 10:16 PM
That's what I was thinking, I've got 2 Subaru's and the cooling system on Subaru's is a bitch to bleed (no experience with VW's converted to Subaru power).
I usually use a vacuum bleeder to get all the air out, and I haven't had a problem yet.
Memberkarmad
posted on January 20th, 2013 at 11:22 PM
post from Joel
So do you all think its air in my system and not anything else?
I will double check the thermostat first?
posted on January 21st, 2013 at 08:19 AM
Wouldn't be a bad idea, it's not opening for a reason and if its working ok it's either the return to it from the headertank is not hot or an air lock in hose somewhere.
Memberian.mezz
Threads: 280
posted on January 21st, 2013 at 12:56 PM
if your radiator is in the front of your car, you dont run that small return line all the way from radiator. just tap a small pipe into to raditor pipe at motor to header tank.
then use that top small hose fitting in radiator for air bleed only.
posted on January 28th, 2013 at 07:52 PM
I've had the motor out my car for a few weeks, I got lazy when I filled the cooling system and I had the same issue as you, fans coming on and the thermostat was closed.
I thought as the rear of the car was jacked up the whole time that I wouldn't need to get too carried away with bleeding.
I had to fill it a few times with the radiator cap off and then as soon as I started to feel heat in the bottom radiator hose I made sure the header tank was topped up and then I put the cap on.
I then let it run through a few heat cycles with the fans coming on & off.
[ Queries: 40 ] [ PHP: 12.6% - SQL: 87.4% ]
