| [ Total Views: 941 | Total Replies: 4 | Thread Id: 100507 ] |
Stephen62
Threads: 4
| posted on January 17th, 2013 at 12:09 PM |
6 volt electronic ignition
I have an early '62 6v 1200 beetle
Has anyone changed the points to electronic ignition in a 6v ?
modnrod
Threads: 50
Mood: Old School Volksies!
| posted on January 17th, 2013 at 02:42 PM |
OOOOOOHHHH!!! That's tricky!
Someone else might know of a 6V dedicated ignition, but I don't. However, I do know about the 6V-12V upconverter that will happily drive a 12V
electronic ignition (like Pertronix, etc).
Have a peek thru Jaycar etc cattledogs, the converter will probably draw 2A or so, so you will need a 300W version. 6V input, 12V output to your
ignition, sweet. Hide it behind the firewall, sweeter.
Just in case you can't get a dedicated 6V unit.
68AutoBug
| posted on January 17th, 2013 at 03:47 PM |
also be beware that if You hook up a pertronix or similar unit and the converter or resistor etc puts out too much voltage the pertronix etc will blow
instantly...
I am sure that You can buy pertronix or similar in 6 volt versions
over seas... marked for 6 volts..??
anyone know if a 12 volt pertronix unit will work on 6 volts???
a bit pricey to experiment with... lol
steve burgess
Threads: 10
Theme: UltimaBB Vintage
| posted on January 19th, 2013 at 10:15 AM |
accu spark .com.uk have a 6 volt version ,it is listed on ebay and i have seen a reference to 6 volt pertronix ign. but unable to actual see a
listing.So they are available .
1956 judson supercharged oval
1975 kombi camper
1976 kombi panel van
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on January 19th, 2013 at 10:20 AM |
http://www.piersideparts.net/D189604.html
