| [ Total Views: 1499 | Total Replies: 12 | Thread Id: 100683 ] |
nsuwift
Threads: 27
| posted on January 29th, 2013 at 09:27 PM |
reverse light switch
Can i fit a reverse light switch to my 67 notch.
If i can where would it go looked at some photos
of gearboxes fitted with them and can't see the
fitting on the nosecone of my gear box.
nsuwift
Threads: 27
| posted on January 30th, 2013 at 10:38 AM |
Just got under the car again looks like I might
have a 6 volt tranny with the bellhousing ground
out to fit 12 v flywheel. Would I simply be able
to fit a 12v nose cone to it, and would that have
the treaded hole for the reverse light switch.
matara
Threads: 255
Mood: 356'd
| posted on January 30th, 2013 at 11:03 AM |
Save yourself the hassle of pulling your engine and gearbox and try and locate one of these Hella switches that works off the speedo cable activated
when the cable twists the opposite way in reverse:-
nsuwift
Threads: 27
| posted on January 30th, 2013 at 02:45 PM |
posted by matara
Thanks steve have found a couple of them on the samba ($75) also found another way by attaching a bracket to the shift rod near the coupling and
mounting switch under the seat ( would have to be under the car for a type 3). This would engage as soon as reverse is selected not after I am already
reversing. My reason for concern is i almost got hit while reversing the other day and if the lights don't come on until I'm moving it may already
be too late.
nsuwift
Threads: 27
| posted on January 30th, 2013 at 02:47 PM |
bosch info sheet
| Error |
nsuwift
Threads: 27
actual photo
| Error |
vw54
| posted on January 30th, 2013 at 07:15 PM |
You can fit the stock one in the nose cone if you have a hex head plug on it
if not u can pull the box n fit a later model nose cone and the stock switch I did this on my 40hp 65 gearbox works great
I had the hella accessory as per above for a few years but the switch in the nose cone works best
dont like the switch on the tunnel
Joel
| posted on January 30th, 2013 at 08:17 PM |
posted by nsuwift
be too late.
One on aussie ebay for $28 at the moment
http://www.ebay.com.au/itm/VW-RARE-50S-60S-70S-BUG-KOMBI-ORIG-HELLA-ACCESSORY...
nsuwift
Threads: 27
| posted on January 30th, 2013 at 09:26 PM |
I have been given this today the part number is 113 301 211 H. It looks to have the same bolt pattern but am worried that it may be different
internally or the hockey stick. The nose that is on my gearbox is part number 131 301 211 then under that it has vw 25.
posted by vw54
vw54 why do you not like the one on the tunnel. Seems fairly simple and effective to me.
| Error |
| Error |
nsuwift
Threads: 27
| posted on February 2nd, 2013 at 08:12 PM |
Going to change the nosecone on my gearbox put a reverse light switch in it and then put these that i found on ebay in the rear reflector housings as
my reflectors are shot.
| Error |
nsuwift
Threads: 27
| posted on February 28th, 2013 at 05:10 PM |
Reverse lights mounted. Now have to change gearbox nosecone and wire them up.
| Error |
| Error |
nsuwift
Threads: 27
| posted on February 28th, 2013 at 05:21 PM |
| Error |
zocstar
Threads: 21
| posted on February 28th, 2013 at 05:54 PM |
Looks good
