| [ Total Views: 1020 | Total Replies: 5 | Thread Id: 100725 ] |
Pfeffernuss
Threads: 16
Theme: UltimaBB Pro Charcoal
Mood: retrospective
| posted on February 2nd, 2013 at 11:47 AM |
Help - releasing the bonnet - type 3 '71
Hi fellas,
I had a numpty at my workshop today, who decided to close my bonnet. The release hadn't been completely secured, and now the bonnet is fully shut.
The cable inside the car has no use, dagnammit.
The spare tyre is also in place.
Any hints to release the bonnet???
Your knowledge is greatly appreciated!
Besser als in die hohle Hand geschissen.
'71 Type 3 Fastback
'08 WRX
'14 Golf Variant HL
68AutoBug
| posted on February 2nd, 2013 at 12:37 PM |
I believe the release is inside the glovebox... same as a late beetle..
If the cable is attached to the bonnet release...
I can't remember exactly how to do it..
but I believe You need to hold the cable outer while pulling the inner... just pulling the inner doesn't work...
its one against the other...
from memory...
Pfeffernuss
Threads: 16
Mood: retrospective
| posted on February 2nd, 2013 at 01:00 PM |
Thanks Lee,
Because we're 3/4 way through this resto, the cable wasn't firmly attached to the latch in the bonnet. One tug and it came right off.
We have the car jacked up, and we are poking the latch mechanism with a broom stick. A calibrated broom stick of course.
Should we be pushing or pulling? Or should we try and thread the cable and do it up...
Thanks, Alex
'71 Type 3 Fastback
'08 WRX
'14 Golf Variant HL
Pfeffernuss
Threads: 16
Mood: retrospective
| posted on February 5th, 2013 at 08:08 PM |
Got it popped! Thanks!
'71 Type 3 Fastback
'08 WRX
'14 Golf Variant HL
vlad01
Mood: Side ways
| posted on February 7th, 2013 at 08:19 AM |
how did ya do it?
I have thought about fixing an additional cable and release in an emergency spot in case this ever happens.
apparently Porsche boxsters have this.
71 notchback,
Dubsky
Threads: 21
| posted on February 7th, 2013 at 07:19 PM |
Im intrigued too! Bad andy had the cable snap on his fasties boot and ended up pulling out the rear left indicator and cutting through the cable
housing to access the piece of wire that was still attached.
