| [ Total Views: 834 | Total Replies: 4 | Thread Id: 100755 ] |
rossdanialnaumov
| posted on February 4th, 2013 at 05:42 PM |
Kombi disc brake dilemma
Hey guys,
Does anyone know the deal on the disc brake change over on 71 - 79 kombi's?
As far as I know 71 - 72 had smaller diameter calliper bolts than the the larger ones found on 72 onwards.
Please correct me if I'm wrong.
Cheers,
Ross
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on February 4th, 2013 at 06:34 PM |
Yep
The '71 calipers had a different caliper bolt and were different in the disc offset/thickness.
Go to a later caliper and discs and life is easier (i.e. you can buy new calipers)
Old Dubber
Threads: 25
Mood: great!
| posted on February 4th, 2013 at 06:40 PM |
Workshop Bulletin dated October 1972.
Shows the larger brake calipers with 14mm pads (previously 10mm), with the caliper pistons lengthened 4mm (from 29 to 33mm).
It also notes the thread on the bolts securing rhe caliper to steering knuckle has been changed from M 12 x 1.5 to M 14 x 1.5. These bolts are to be
tightened to 14.5 - 17.5 mkg. The fitted bolt is screwed in at the top on the new calipers (previously at the bottom).
bussboy
Threads: 27
| posted on February 4th, 2013 at 06:57 PM |
This is also a very handy thread
http://www.thesamba.com/vw/forum/archive/index.php/o-t--t-285871--.html
rossdanialnaumov
| posted on February 6th, 2013 at 04:01 PM |
Thanks heaps bussboy vassy66T1 and Old Dubber, all the information I need.
Cheers!
