| [ Total Views: 816 | Total Replies: 12 | Thread Id: 100817 ] |
gotthebug65
Threads: 31
Mood: ok
| posted on February 9th, 2013 at 05:27 PM |
Bugpack 3/8" Chromoly Pushrods how to
Hi all anyone put these pushrods together before ?
How too... need to be pressed in ?
http://vwparts.aircooled.net/Bugpack-3-8-Chromoly-Pushrods-Set-of-8-p/4053.htm
matberry
| posted on February 9th, 2013 at 05:59 PM |
You need to work out the length and cut the pushrod to length, then press the ends in using two old lifters. A hammer works, a press is better.
66deluxe
Threads: 139
Use two old lifters to support each end then tap the end in by hitting old lifter with soft face hammer.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
gotthebug65
Threads: 31
Mood: ok
| posted on February 9th, 2013 at 07:10 PM |
Cheers for the tips mate....
would the length needed be different due to running the empi style 1.4 rocker?
stock cam and the rod length is 11.600
posted by matberry
gotthebug65
Threads: 31
Mood: ok
posted by 66deluxe
matberry
| posted on February 9th, 2013 at 07:17 PM |
You need to set rocker geometry and then pushrod length, but IMO a wouldn't be running 1.4 rockers with a stock cam, also 1.4 rockers need lash caps
fitted.
gotthebug65
Threads: 31
Mood: ok
| posted on February 9th, 2013 at 07:46 PM |
Fair enough mate do i need to pull the motor to fit a cam ? i am trying to get a bit of extra power out of my 1500 on a budget i want to build a 1915
hope fully start later this year so figured i could use the part on the build later on .....
Anyway once again cheers for the info
posted by matberry
fitted.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on February 9th, 2013 at 07:49 PM |
Yeah but highly likely you will need different length pushrods when you go to 1915
gotthebug65
Threads: 31
Mood: ok
| posted on February 9th, 2013 at 07:58 PM |
meant to say parts..... and i was referring to the rockers
thanks for the imput.
posted by hellbugged
vwo60
Threads: 71
Mood: good
| posted on February 10th, 2013 at 09:58 AM |
It is good practice to machine the push rods in a lathe to get the square on the ends.
gotthebug65
Threads: 31
Mood: ok
| posted on February 10th, 2013 at 04:08 PM |
im starting to think i might just fix the oil leaks in the 1500 save the parts ive bought for a motor build......
cheers again
posted by vwo60
Lucky Phil
Threads: 16
Mood: I'm a legend in my own lunchtime!
| posted on February 10th, 2013 at 08:36 PM |
Makes sense to me.
SuperOwen
Threads: 67
| posted on February 10th, 2013 at 08:46 PM |
I used 1.4's on a stock cam on my last 1600, went ok. ended up being a bit shorter than stock pushrods, I just shortened stock aluminium ones.
