| [ Total Views: 1289 | Total Replies: 21 | Thread Id: 101350 ] |
tar76
Threads: 95
| posted on March 25th, 2013 at 06:24 PM |
Give Rod Penrose a bell mate, he sells good weber carbs and whole kit
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
vw54
| posted on March 25th, 2013 at 06:44 PM |
STAY away from anything that says E M P I
Bizarre
| posted on March 25th, 2013 at 07:12 PM |
I am no expert on type 3's but I dont believe I have ever seen a single carb on one??
Well - here is one
http://recarb.com.au/type3-2brl-carburetor-p-38.html?osCsid=263679d2f94ba2e8a...
But it reads as though you have to cut the engine cover
I would certainly think about a set of dual IDF or DRLA carbs
You will need shorty manifolds
Either that or seriously think about getting your original carbs rebuilt and a new linkage set up
Bizarre
| posted on March 25th, 2013 at 07:30 PM |
http://www.ebay.com.au/itm/VW-1600-WEBER-40-IDF-CARBURETORS-/261152755759?pt=...
http://www.ebay.com.au/itm/VW-PORSCHE-DELLORTO-DRLA-40-CARBURETORS-/290874996...
http://www.ebay.com.au/itm/VW-PORSCHE-DELLORTO-DRLA-36-CARBURETORS-/290865738...
plus manifolds, filters, linkage etc etc
Super1302
| posted on March 25th, 2013 at 08:38 PM |
Don't get new webers, well the 44's I've had were porous, won't get UNLESS they're Italian. Try some decades off Rod if he has, same fit as IDF.
matberry
| posted on March 25th, 2013 at 08:46 PM |
^ I've fitted 3 sets of new Weber IDF's in the last 6 months with no problems
Notchbacktastic
Mood: Mustard
| posted on March 26th, 2013 at 07:40 AM |
Did someone say FUEL INJECTION!?!
Not my engine/car...
| Error |
Ain't been there, ain't done that.......yet :P
dragsters for life
Threads: 51
Mood: always a happy chappy
| posted on March 26th, 2013 at 05:08 PM |
cant beat stock carbs, just have them rebuilt, you dont want to change performance so i dont see a point in buying new ones, a freshen up is always
good
Super1302
| posted on March 26th, 2013 at 06:16 PM |
Have had two pairs of webers, 3 out of the 4 were porous, need to get Italian ones if you want to stay with weber, but yeah thedecade runs sweet on my
2332 out of the box
tar76
Threads: 95
| posted on March 27th, 2013 at 07:18 PM |
Good one danny, we've all been there mate! Now go drive and enjoy
"Obey your Dreams"!
62 Std beetle.
Super1302
| posted on March 27th, 2013 at 08:11 PM |
Great news
Super1302
| posted on March 27th, 2013 at 08:16 PM |
Fuel pump you say, I have a facet barrel type that has a filter within the housing, you can empty it, but......I do have a filter before it and I have
the pump below the tank.
The pressure on my gauge out the back to the carbines is approx 3 psi which is good.
vlad01
Mood: Side ways
| posted on March 27th, 2013 at 10:29 PM |
I personally would do away with the carbs and dizzy and go for EFi. either MS or delco based system.
71 notchback,
1916baja
Threads: 176
| posted on April 1st, 2013 at 08:30 PM |
I have a genuine USA made facet low pressure electric fuel pump for sale for 50 bucks if you're interested...
I'm at mt Gravatt.
Klaus
Threads: 100
Mood: Heavily modified
| posted on April 2nd, 2013 at 09:02 PM |
theres nothing wrong with stock carbs if there looked after and setup right , vw werent idiots .. just make sure all surfaces are flat where a gasket
sits and shafts are within tolerance , i've converted the linkage to aftermarket ones and changed out the solenoids on the side to fixed jets make
sure the carbs are balanced and motors run sweet .
