[ Total Views: 737 | Total Replies: 8 | Thread Id: 101539 ]
Author: Subject:  Will post 61 front drums fit 56 oval stubs?
posted on April 8th, 2013 at 10:19 PM
Hi all, got some brake dramas and can't find parts. Am thinking of upgrading to post 61 front drums. Discs are a complete disaster, already looked into that and NSW roads department are in the middle of having kittens with engineers about it.
So I want to know if the backing plates of post 61 front drums will bolt up to Oval stub axles. If anyone has a post 61 backing plate, I'd appreciate a pic of it to compare with what I have here. Thanks.
MemberAnthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
posted on April 9th, 2013 at 05:38 AM
Have you tried getting the cylinders from the states Pete
http://www2.cip1.com/mobile/default.aspx#P6547
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
Membervwo60
Threads: 71
Mood: good
posted on April 9th, 2013 at 07:29 AM
I think the subs and backing plates have the same bolt pattern and should fit, also the spindle, i have a set of a 64 if you want to try them.
MemberHappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on April 9th, 2013 at 07:47 AM
May by worth thinking about replacing the rears as well, otherwise there will be a miss-match.The later [F & R] brakes are wider.
posted on April 9th, 2013 at 08:26 AM
The dums will fit if the brakes and backing plates get changed too. The 40hp brakes will push your wheels out nearly 10mm
posted on April 9th, 2013 at 12:22 PM
Thanks guys, have looked into it and am going to upgrade. I've already got type 3 rear drums and a twin circuit master, so this is the logical conclusion... it will stop heaps better. And the parts are less than half the price too.
Re the wider track, there's already room for that. But thanks for letting me know. :)
Memberpsimitar
Threads: 148
posted on April 9th, 2013 at 11:28 PM
Here's a picture of my 59/60 front backing plate
http://i7.photobucket.com/albums/y252/psimitar/59%20Beetle/DSC00864.jpg
I reckon you'll be alrite as don't believe the stub axle changed until the BJ beam. You will however have 40mm wide drums and shoes as these came in 1958. :)
posted on April 14th, 2013 at 08:27 PM
Just a quick update. New drums on, bled up and shoes bedded in. And...... it stops a heck of a lot better. Tops upgrade without all manner of conversion dramas. :tu:
I'm digging 1963 technology! :D
posted on April 14th, 2013 at 08:42 PM
I just noticed this thread
similar to my oval i drive, but i did it 15 years ago.. Good to see you have got with the times to pull it up :D
nice one and stops good too :tu:
