[ Total Views: 575 | Total Replies: 6 | Thread Id: 101570 ]
Author: Subject:  Trouble removing Flex Plate
Membersatori
posted on April 11th, 2013 at 09:10 PM
Hi all. Im trying to remove a flex plate off a 2.1 wasser and replace it with a fly wheel. The 5 hex head boilts just wont budge. Tried with a impact wrench but with no results. and with a long wrench with a hex head socket but almost stripped them. Any ideads.
[URL=http://s1226
Memberdonn
Threads: 428
Mood: LAID BACK AND CONFUSED
posted on April 11th, 2013 at 09:14 PM
Drill the heads off? once the load is off then the remainder of the bolt should be able to be removed easily.
posted on April 11th, 2013 at 09:29 PM
^^Unless they've been loctited???
Heat and replace bolts
Memberragged
A.k.a.: David
Just ask if you need HELP!
Threads: 46
posted on April 12th, 2013 at 11:09 AM
Get a better quality socket. You will find heavy duty sockets only have 6 flats to contact the bolt head.
Dave
Membervlad01
Mood: Side ways
posted on April 12th, 2013 at 12:40 PM
Dave
yes and long breaker bar.
those bolts I think are like 80 or 90 ft-lb so yeah thats tight for their size.
71 notchback,
MemberVolksVair
Threads: 32
posted on April 13th, 2013 at 08:42 AM
Daves on the money with a single hex socket, if you want to round bolts & nuts go the double hex, I allways use single hex to crack a bolt/nut then use the double hex to remove if its in a confined area
Adventure Before Dimentia
Membergrumble
Mood: happy all the time
posted on April 13th, 2013 at 06:37 PM
And use the single hex,the heat will help crack the loctite.
