[ Total Views: 842 | Total Replies: 2 | Thread Id: 101574 ]
Author: Subject:  1600 TP header change - j-pipes - fan ducting question
MemberPfeffernuss
Threads: 16
Theme: UltimaBB Pro Charcoal
Mood: retrospective
posted on April 12th, 2013 at 11:34 AM
Hey Air-heads,
I have installed J-pipes on the 1600 TP i have just finished rebuilding. when running, the fan housing pushes air over the heads and also into the exhaust/heat exchanger. now that i dont have a heat exchanger, the air will blow over the heads and straight into the street below.
question.
if you install j-pipes, is it common practice to block up the heat exchanger duct. and what method do you use to block it? (rubber + hoseclamp?).
result.
i assume that all that will occur is that more of the air will be routed to blow over the heads.
appreciate you insight.
Before:
https://dl.dropboxusercontent.com/u/65882708/20120602_113410.jpg
After:
https://dl.dropboxusercontent.com/u/65882708/IMAG0009_BURST001.jpg
Besser als in die hohle Hand geschissen.
'71 Type 3 Fastback
'08 WRX
'14 Golf Variant HL
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on April 12th, 2013 at 12:07 PM
Yes just rubber and hose clamps
Make sure the carb manifolds are down tight to the heads, spark plugs and leads are good before you install the engine. Twin carbs and type 3 are a pita to work on
Membersplit
posted on April 12th, 2013 at 03:49 PM
or the lid of a spray can
[ Queries: 40 ] [ PHP: 12.1% - SQL: 87.9% ]
