| [ Total Views: 831 | Total Replies: 7 | Thread Id: 101587 ] |
peter87
Threads: 42
| posted on April 13th, 2013 at 12:08 PM |
Help: Clutch Problem 1600cc Bug
Hey guys,
Just put a rebuilt engine in my bug. It's running and idling well but when the car is on you are not able to shift into any gear.
If you move the shifter into first gear or any gear and then start the vehicle it will just jolt forward and stall.
Is this just an issue of not aligning the engine up to the gear box properly when installing, or is this to do with the clutch cable?
Any help/advice would be appreciated
peter87
Threads: 42
| posted on April 13th, 2013 at 12:09 PM |
Also forgot to mention since new engine swap the pedal does not seem as tight as it once was.
grumble
Mood: happy all the time
| posted on April 13th, 2013 at 01:49 PM |
Have you adjusted the cable?
Anthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
| posted on April 13th, 2013 at 03:06 PM |
Did you change the clutch or throw out bearing?
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
Joel
| posted on April 13th, 2013 at 03:24 PM |
Agreed, you havent put a 70s 1600 and clutch into and early gearbox have you?
if so you'll need an earlier clutch with the throw out bearing collar.
peter87
Threads: 42
| posted on April 14th, 2013 at 11:14 PM |
Thanks guys but worked it out. Nut on the clutch cable just needed adjusting
h
| posted on April 14th, 2013 at 11:25 PM |
right there
grumble
| posted on April 15th, 2013 at 07:56 AM |
posted by grumble
| It is usually something simple that is overlooked then panic sets in.
