| [ Total Views: 2502 | Total Replies: 35 | Thread Id: 101760 ] |
| Pages: 1 2 |
EnPassant
Threads: 1
| posted on May 5th, 2013 at 11:52 AM |
posted by h
erm if you have paid for something and it hasn't been fixed take it back and get them to fix it..?
if u forked out $644 for nothing well that doesn't add up..
surely they must have done some work that you agreed to yeah..?
which vw service place is it?
send them an email n get something done about it.. wtf
Certainly I will be contacting them again (politely) but it is simply not practical for me to drive another 200km round trip, waste a whiole day
hanging around while they quite possibly still fail to find the fault and charge me another $130+ per hour for the privelege. (Remember - they told me
only after working on the vehicle, that they don't have the diagnostic equipment for older vehicles. This was even though I had told them the age and
model of the vehicle when booking it in and stressed that I was travelling to see them because of their advertised diagnostic capabilities). In the
meantime it is more practical for me to replace a few parts which I can source relatively cheaply.
EnPassant
Threads: 1
| posted on May 5th, 2013 at 11:59 AM |
posted by 11CAB
posted by EnPassant
posted by 11CAB
Yep there's a rubber plug for it. It's taken out to check the timing mark on the flywheel
Thanks. Any idea what its called so that I can search for one? I live on a dirt road and grit is likely to get in there
VW just call it a plug.
Should be 02A301115A
Thanks. I will check it out. - And thanks again for taking the time to help me solve the stalling issue. I will post updates as I replace the parts
which are possible causes of the problem.
EnPassant
Threads: 1
| posted on May 13th, 2013 at 04:13 PM |
posted by 11CAB
No 30 Relay powers up the ECU. When the solder joints crack, it turns the power off to the ECU like you've turned the key off. It doesn't store a
fault code, because it thinks you've turned the key off.
Hi again. I replaced the 30 relay with a new one but it made no difference so I am waiting on a new Idle Air Control Valve which is my next move. Will
post again when it is fitted.
matberry
| posted on May 13th, 2013 at 05:48 PM |
Often a clean can improve the IAC
EnPassant
Threads: 1
| posted on May 13th, 2013 at 06:01 PM |
posted by matberry
Hi Matberry. That was one of the first things done so now I'm hoping a new one might do the trick!
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on May 13th, 2013 at 06:11 PM |
If its a 2.0L 4cyl motor, replace ALL the vac hose going to the ECU
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
| Pages: 1 2 |
