| [ Total Views: 835 | Total Replies: 7 | Thread Id: 101892 ] |
dstevenson101
| posted on May 5th, 2013 at 06:26 PM |
UPDATE: starter motor for 71 super bug (1600)
Hi all,
I'm looking for a cheap starter motor just to get me by for the next little while.
Mine has gone kaput!
Beetle is off the road for other body repairs at the moment but it would be good to be able to move it around rather than push it
I'm in Adelaide , if anyone has a working one that is spare laying around and wants to get rid of it please let me know.
Cheers Dale
1971 Super bug
Bizarre
| posted on May 5th, 2013 at 06:43 PM |
are you sure it is the starter motor??
Quite often it is the bushing and the pivot(?) binds and doesn't engage properly
dstevenson101
| posted on May 5th, 2013 at 08:18 PM |
no I'm not 100% sure....
If i try to start it, I get absolutely nothing when I turn the key. I'f I get under the vehicle and belt the starter with a hammer it frees it up a
bit to turn over half a turn or so.
So my conclusion was... there is definately power to the starter, so not a solinoid or power issue.
what is this pivot and bush you speak of>?
1971 Super bug
Bizarre
| posted on May 5th, 2013 at 08:43 PM |
have a read here
http://www.vw-resource.com/starter.html
and here
http://www.vw-resource.com/car_wont_start.html
The bush is the brass ring in the picture
If that wears, the starter motor doesnt engage properly.
Can you borrow a starter??
You "can" replace the bush insitu but it is a pain in the arse.
You can but hi-torque, bush less starters, but they are about $350
Whateve - have a play and get back to us
| Error |
dstevenson101
| posted on June 30th, 2013 at 08:11 PM |
UPDATE!!... Ok after a few distractions with the bug (fixing some rust... ) I have a new starter to put it the new starter came with the brass bush
as well.
Bizzare said that replacing this can be done insitu (although a pain in the butt),
Can anyone provide some tips on how to do this?
Im yet to get under there and have a look, however i suspect this brass rind in tightly held into place?? and if so, are there any tips/tools to use
that would make the replacement this a little easier in the tigh space that I have to work with.
It is my preference to replace this bush at the same time as putting in the new starter, as then I know it is done, and should last for another 42
years.
Cheers.
Dale
1971 Super bug
AA003
A.k.a.: Phill
Threads: 39
| posted on July 1st, 2013 at 03:29 AM |
Soak the bush in oil overnight before using. Wind a tap into the old bush and pull it out.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
1303Steve
| posted on July 1st, 2013 at 12:54 PM |
posted by AA003
just keep winding the tap in, once it bottoms out it will push the bush out
dstevenson101
| posted on July 1st, 2013 at 08:51 PM |
thanks guys... guess i better go buy myself a tap....
1971 Super bug
