[ Total Views: 1044 | Total Replies: 1 | Thread Id: 101899 ]
Author: Subject:  Adjusting ride height on 944 spring plates
posted on May 5th, 2013 at 10:19 PM
On my other cars using 944 spring plates and 23.5 mm torsion bars I had no trouble adjusting the height, I locked 2 nuts onto the spring plate height adjuster and I was able to turn the adjuster to reset the suspension height.
This method wasn't working well on my new 1303 which has 26 mm short torsion bars.
So I searched eBay for a thin 36 mm spanner so that I could do the adjusting the way Porsche intended, using the 36 mm nut.
I found this spanner that is used Land Rover Discovery 2 TD5 36 mm viscous fans. I just used it then and it works great, I did have to remove the bolt that the sway link goes on to give me enough room.
MemberSides
A.k.a.: Dave Sidery
posted on May 5th, 2013 at 10:31 PM
Nice find Steve... would come in handy for doing camber adjustments on "tractor front ends" too !!!
:tu:
My toys
[ Queries: 40 ] [ PHP: 12.1% - SQL: 87.9% ]
