[ Total Views: 854 | Total Replies: 18 | Thread Id: 101997 ]
Author: Subject:  heat wrap
Membergrogy
Threads: 344
posted on May 12th, 2013 at 12:10 PM
heat wrap
hi, can anyone tell me anything about or not to buy a certain type of heat wrap. thanks greg
Membervwo60
Threads: 71
Mood: good
posted on May 12th, 2013 at 12:14 PM
Is this for the exhaust, what it its aplication.
Membergrogy
Threads: 344
posted on May 12th, 2013 at 12:20 PM
yes for exhaust trying to stop tinware above exhaust heating up. my valance has already bubbled the paint from exhaust. so i even thought of sticking it under the tinware
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on May 12th, 2013 at 12:32 PM
i think the last time i saw some used it was just the one from supercheap or autobarn.
worked ok.
the chaos project - click me
Membervwo60
Threads: 71
Mood: good
posted on May 12th, 2013 at 01:13 PM
You can get a fiberglass bandage, we use it at work as a heat proof gasket, i have used it wrap my oil cooler lines between my exhaust, the only down side is the possibility of heat stress corrosion were the insulation gets wet and eventually it can cause the exhaust to crack, how are your mixtures, i had a simailar problem and fixxed the issue by rejetting the carbs.
Membergrogy
Threads: 344
posted on May 12th, 2013 at 01:49 PM
thanks for the replies, i think my jetting at idle is in the ball park, not sure, maybe too rich up top. i been reading about wraps on exhaust, i think i bypass that n coat the tinware above the exhaust. is the fibreglass wrap just like the one at supercheap. i even thinking about ringing my fireman mate n ask him about fire blakets
Membergrogy
Threads: 344
posted on May 12th, 2013 at 01:52 PM
looks neat under u engine bay
MemberAA003
A.k.a.: Phill
Threads: 39
posted on May 12th, 2013 at 03:42 PM
Asbestos tape is what us oldies use!
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!:lol:
Membernewghia
A.k.a.: Noddy
Threads: 30
Theme: UltimaBB Pro Charcoal
Mood: nood !
posted on May 12th, 2013 at 05:01 PM
I've used it & found it to help, make sure you put it on wet otherwise it gets quite itchy
Step up to get out !!!
MemberPhil74Camper
Head in the Clouds
Threads: 193
posted on May 12th, 2013 at 05:42 PM
I wrote an article on this for the VW Club magazine back in 1997. It works well but will eventually ruin your exhaust headers.
http://www.clubvw.org.au/oldart016#exh08
Memberrose
doin it for d girls
Threads: 308
Theme: UltimaBB Pro Red
Mood: always happy
posted on May 12th, 2013 at 06:06 PM
:blush:
[img][/img]
Membergrogy
Threads: 344
posted on May 12th, 2013 at 06:22 PM
thanks rose but u pic wont display. i decided not to use wrap i put heat shield under the tinware at the pulley end and also on back of the valance.....
posted on May 12th, 2013 at 06:28 PM
What you'v done is better as the fibreglass wrap does prematurely wreck the exhaust no matter what it's made of. Ceramic coating significantly reduces the radiant heat.
Memberkarmann141
Threads: 48
posted on May 12th, 2013 at 06:44 PM
I'd like to know where you can get asbestos tape from as it is prohibited and totally illegal in Australia - for obvious reasons.
1961 K Ghia - Porsche 5 sp, EJ20T, Brembo's, Dble A arm susp
1974 L Bug - Porsche 944 brakes, Boxster 16's
1974 Bay Camper - EJ20, twin radiators, Boxster 16x7's
Half Beetle trailer with Boxster 16x7's
2011 Tiguan TDI 4Motion
2010 LR Discovery 4 TDV
MemberAA003
A.k.a.: Phill
Threads: 39
posted on May 12th, 2013 at 07:06 PM
Oh sh1t! I'd better throw it in the rubbish bin then.
Memberkarmann141
Threads: 48
posted on May 12th, 2013 at 09:29 PM
Just make sure you wet it down, seal it up, label it and send it to secure landfill:crazy:
MemberAA003
A.k.a.: Phill
Threads: 39
posted on May 13th, 2013 at 07:29 AM
I just put it in the bin at the child care centre. They won't mind.
posted on May 13th, 2013 at 08:13 AM
I used ACL Heat Shield that you can buy from Repco, any double skinning on the back of the rear apron will reduce heat.
HR140-GTR IS A REVOLUTIONARY HEAT SHIELD MATERIAL. Its construction, consisting of a ceramic filler sandwiched between two 0.15mm aluminised steel sheets, gives a very efficient high temperature thermal barrier suitable for a wide variety of automotive and industrial applications. The unique double corrugation design allows the material to be formed into complex shapes and ensures exceptional rigidity. This material provides excellent performance in high temperature, noise sensitive applications. HR140-GTR material is available in a range of sizes.
HR140-GTR Heat Shield Material
MATERIAL SPECIFICATIONS
Construction: 2 x aluminised steel sheet with ceramic paper insert, double corrugated
Product Thickness: 3.5mm
Max Temp: 850 °C - 900 °C
Membergrogy
Threads: 344
posted on May 13th, 2013 at 08:21 AM
yea thats the stuff i used,............ after all i read about wrap i would only use it, if i had to work around hot parts
