| [ Total Views: 1164 | Total Replies: 21 | Thread Id: 102025 ] |
vwo60
Threads: 71
Mood: good
| posted on May 15th, 2013 at 08:55 AM |
a good vw replacement engine
http://www.pompolodesign.com/pompolo-design-works.html
| Error |
vwo60
Threads: 71
Mood: good
| posted on May 15th, 2013 at 08:59 AM |
Internals
| Error |
vlad01
Mood: Side ways
| posted on May 15th, 2013 at 09:02 AM |
hang on? what this engine?
911 engine with 2 cylinders chopped off?
wow wtf!
71 notchback,
68BUS
Threads: 19
Mood: Berwildered
| posted on May 15th, 2013 at 09:26 AM |
And what is with the chain?
Does that live inside the engine all the time or is a build thing?
1966 Aussie 11 Window
kombibob
Threads: 173
Mood: at by cows
| posted on May 15th, 2013 at 09:45 AM |
Wtf! Very cool
1961 swb buggy
1960 karmann ghia
2012 Skoda Octavia scout
Get down low and go,go,go
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on May 15th, 2013 at 11:20 AM |
posted by 68BUS
Drive chain for the over head cams.
matberry
| posted on May 15th, 2013 at 11:26 AM |
And look at all those main bearings. Awesome, looks like they have cast thier own block and crank and the rest is Porsche....very nice, 175 hp
too......
sander288
"Bolt-on Master"
Threads: 183
| posted on May 15th, 2013 at 11:56 AM |
http://www.capricorngroup.net/fileadmin/files/images/capricorn_Anzeige_Motors...
^^^ something else if you've got the dosh!
ragged
A.k.a.: David
Just ask if you need HELP!
Threads: 46
posted on May 15th, 2013 at 01:15 PM |
Some engines are designed right from the
beginning with performance as a priority. (see pic above)
Some are designed to cost as little $$$ to produce. (Look in your driveway)
The thing they have in common are they are able to be driven flat out all day and get you home.
The saying, "can't make a silk purse out of a pigs ear" is beginning to make perfect sense!
Dave
Subarugears
Threads: 17
| posted on May 15th, 2013 at 01:52 PM |
Wow, I had a look at their 718 5 speed gearbox. $40,000 Euro plus VAT, packing and shipping!!!!!!
vlad01
Mood: Side ways
| posted on May 15th, 2013 at 01:58 PM |
posted by 68BUS
that drive the cams on the head. the shaft to which they are connected to is not a cam but the IMS. That thing with the green o rings is a 2 stage
dry pump by the looks of it.
71 notchback,
vlad01
Mood: Side ways
| posted on May 15th, 2013 at 04:24 PM |
I like the locating pins in the main saddles.
71 notchback,
vwo60
Threads: 71
Mood: good
| posted on May 15th, 2013 at 05:51 PM |
Only $30.000 for the basic engine, up to 2.8Ltr can be built, ready to turbo.
vlad01
Mood: Side ways
| posted on May 15th, 2013 at 10:09 PM |
sounds bout right, thats what an engine like that would go for.
71 notchback,
68BUS
Threads: 19
Mood: Berwildered
| posted on May 16th, 2013 at 08:36 AM |
Thanks for the answers on the chains fella's.
Craig Torrens
Threads: 347
| posted on May 16th, 2013 at 09:01 AM |
$156k for the motor.........faaark !
http://www.capricorngroup.net/fileadmin/files/documents/Artikel/Preisliste_cc...
vlad01
Mood: Side ways
| posted on May 16th, 2013 at 11:48 AM |
I was like what kind of engine cost that much?
then I looked, Carrera quad cam, of course. They cost a min of 100k for a rebuild original. So yeah thats not so ridiculous given what they go for.
but still, deep pocket people only.
71 notchback,
pete wood
| posted on May 18th, 2013 at 08:50 PM |
I remember reading somewhere about plug changes on these motors. Apparently you needed an "asbestos octopus" or you just pulled the whole motor
out....
I'll be keeping my stocker for now I reckon.
Bizarre
| posted on May 25th, 2013 at 11:33 AM |
So how do you set your valves on one of them motors??
vwo60
Threads: 71
Mood: good
| posted on May 25th, 2013 at 05:22 PM |
Plugs would take ten minute's and are visable in the view of the engine in the car, the valve adjustment is the same as a 911 with adjusting screws
using a 13 mm spanner and a special feeler gauge.
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on May 25th, 2013 at 05:58 PM |
posted by vlad01
You certainly wouldn't buy it for the HP! $ per HP could go a VERY long way at half that budget. Just saw they wanted $19,000 for a crankshaft! and
$2200 for a distributor... wow!
Parts wise, must be the worlds best paid fitters and turners.
(ô_!_/ô) (ô_!_/ô)
vwo60
Threads: 71
Mood: good
| posted on May 25th, 2013 at 09:28 PM |
Nothing to do with highly paid fitters and turners, limited production, exclusivity and quite a few people who would not think twice about it.
