| [ Total Views: 750 | Total Replies: 9 | Thread Id: 102477 ] |
vinsueball
Threads: 22
| posted on June 18th, 2013 at 08:24 PM |
WTB - Heater parts for 1970 VW Beetle
Hi Folks,
Just wondering if anyone can help me out with:
A set of Bakerlite heater connector tubes that comes through under the rear seats
2 - The valve that sits inside the left hand rear heater junction piece that directs heat down the main passenger side sub-frame
The first item has been damaged in the resto but can perhaps be repaired with fibreglass. The second item (the valve) is missing totally and if I
can't get a replacement I'll have heated air constantly pumping into the cabin.
Can anybody help with these parts or tell me where I may be able to locate them ?
I'm located in the northern Brisbane suburbs.
donn
Threads: 428
Mood: LAID BACK AND CONFUSED
| posted on June 18th, 2013 at 08:42 PM |
Send or post a pic, I may have them but in Newcastle
vinsueball
Threads: 22
| posted on June 18th, 2013 at 09:14 PM |
Thanks,
I'll see what I can do to get some pics up.
68AutoBug
| posted on June 18th, 2013 at 11:20 PM |
I don't think they are available new..
but there should be many of the parts available from people who have pulled a 68> beetle apart..
unless they were labelled unimportant and were trashed..
as were many little things that don't normally wear out.. lol
there would have been a lot of these gone into the trash with rusted out chassis....
Not sure about what number two is..??
I know there are valves/flaps both sides which turn the HOT air on in the back... [used them tonight].. lol
when You PULL the heater lever UP - You turn the HOT air ON.. which comes in the front floor and windscreen..
PULL the other lever UP which opens the two rear seat flaps/valves.. which fill the car with HOT air..
[is that what You need? one of those??]
BUT unless the HEATER is turned ON first... NO HOT AIR comes out the rear outlets...?? I always pull both Levers UP..!
they are just connected to the heater channels, so when the heater is turned off, no hot air from the heater boxes..
This is with a 1968>> ON Beetle... with two levers...
posted by vinsueball
Hi Folks,
bushed
Threads: 66
| posted on June 19th, 2013 at 11:11 AM |
kombis have a separate valve cap unit which should fit on the end of yours I HAVE 3 avail .....or I will exch your box for a good one (more work
but)...
u can pic up ()or swap at Mt Gr East Sun nite 04212 86423
vinsueball
Threads: 22
| posted on June 19th, 2013 at 09:55 PM |
Hi Guys,
These are the parts I'm after.
This is the bakerlight connection. Even if I could just get the drivers side unit would be good.
http://s1292.photobucket.com/user/vinsueball/media/IMG_1054-2_zpsd4a9caa8.jpg...
This is the valve unit I'm after for the passenger side. Just the valve not the housing.
http://s1292.photobucket.com/user/vinsueball/media/IMG_1062_2_zps54553e8c.jpg...
Any chance do you think ?
Special Air Service
Chief "Gunna"
Threads: 210
| posted on June 22nd, 2013 at 09:28 AM |
should have both of those mate, will have a dig & let you know.
Brendan
[size=5] Calling all NSW Mid North Coast Veedubbers
Click Below [/size]
[size=6]Mid North
Coast VW [/size]
vinsueball
Threads: 22
| posted on June 24th, 2013 at 09:02 PM |
Would appreciate it. Let me know how you go ? Only other option I've got at the moment is to try to fabricate something.
Special Air Service
Chief "Gunna"
Threads: 210
| posted on July 14th, 2013 at 10:29 AM |
found them mate, will get pics to you shortly.
Click Below [/size]
[size=6]Mid North
Coast VW [/size]
Special Air Service
Chief "Gunna"
Threads: 210
| posted on July 22nd, 2013 at 08:46 PM |
you "should" have a PM & email
Click Below [/size]
[size=6]Mid North
Coast VW [/size]
