| [ Total Views: 1177 | Total Replies: 15 | Thread Id: 102503 ] |
Dazz
Threads: 22
| posted on June 21st, 2013 at 07:53 PM |
Help: location of flasher can 76 L Bug
I need help, I can't find my flasher can. Maybe it's not there. Where should I be looking as I want to get the electrics sorted.
57 oval
Oval type 4 Fuel Injected
Threads: 48
Mood: Oval
| posted on June 21st, 2013 at 07:59 PM |
Reckon its behind the fuse box in the centre of the dash
Bizarre
| posted on June 21st, 2013 at 08:07 PM |
That is correct if its an L bug - curved screen.
If its 1976 standard I am not so sure
Bizarre
| posted on June 21st, 2013 at 08:15 PM |
You need to take the cover off the fuse box thing then lay on your back and slide in under the dash
AA003
A.k.a.: Phill
Threads: 39
| posted on June 21st, 2013 at 09:16 PM |
Ls finished in '75.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
Joel
| posted on June 21st, 2013 at 10:06 PM |
If it was a standard 76 he would have found the flasher by now, they are staring you in the face in a 76.
Theres a few later 75 Lbugs out there people have been calling 76s often gets passed on from owner to owner but yes they finished in mid 75.
To find the relay on an Lbug you need to drop the fuse box down, there are 2 screws recessed in either side.
The relays are all slotted in along the back
68AutoBug
| posted on June 22nd, 2013 at 12:30 AM |
posted by Dazz
it won't be a common old flasher can... though... lol
beetleboyjeff
A.k.a.: Jeff Walsh
Threads: 40
Mood: Drive bugs hard
| posted on June 22nd, 2013 at 07:36 AM |
posted by 68AutoBug
They are pretty common - I bought one easily enough from Autobarn about 18 moths ago.
From your ole' mate Jeff
TorxKiwi
A.k.a.: Dean Newell
Threads: 38
Mood: "It's not easy being green"
| posted on June 22nd, 2013 at 10:48 AM |
Joel's photo is a bit misleading because he has twice as many relays as others to run all his toys!!!
"Ownership of a Beetle is not a destination it is a journey."
Joel
| posted on June 22nd, 2013 at 11:07 AM |
Well yes, the 2 on the right are the only stock relays.
Outer right one is indicators and the aluminium one is high beam dip.
Middle and left 2 are intermittent wiper and headlight upgrades.
68AutoBug
| posted on June 22nd, 2013 at 01:19 PM |
posted by beetleboyjeff
posted by 68AutoBug
Hi Jeff
well the common ones I know and have are little and large round plastic or aluminium ones with 2 or 3 pins..lol
I had a problem with My VW flasher relay [wires came off] lol in My beetle which is a large rectangular shape so I'm just using a small elctronic 2
pin flasher at the moment..
until I get the fusebox wired up.. using circuit breakers also..lol
Dazz
Threads: 22
| posted on June 23rd, 2013 at 09:29 PM |
Thanks guys. It is an L bug, curved screen and the vin apparently shows a 6 that someone in the know told me makes it a 76. Not being as familiar as
the Penrose family, who am I to question it.
Dazz
Threads: 22
| posted on July 5th, 2013 at 11:44 AM |
Finally got it out today,
will chase one up over the weekend.
Thanks guys
andrewmurphy
Threads: 22
| posted on July 6th, 2013 at 12:38 PM |
Give a vw dealer with a parts department a go. I was after a set of wheel bearings kits for my car (69 bug)and shopped around and was driving past a
vw dealer and they had them in stock and were about half the price that the after market vw shops were telling me. That was a few years ago but you
never know.
Joel
| posted on July 6th, 2013 at 02:38 PM |
You would pay through the nose buying one from a stealership, when the quality generic ones work perfectly fine from somewhere like Autobahn and are
100x cheaper.
You just need the right pin layout for a Euro car which is positive on the right.
Dazz
Threads: 22
| posted on July 8th, 2013 at 12:12 PM |
Joel, photos were a huge help, located it straight away (once I had time to look).
Autopro had a Hella one for $25 or could get a genuine for $84 on a very old price listing.
Put it just now and have working indicators.
Thanks for the advise guys, I will need more as the build progresses.
