| [ Total Views: 1755 | Total Replies: 11 | Thread Id: 102609 ] |
andrewmurphy
Threads: 22
| posted on July 1st, 2013 at 03:26 PM |
Trailers
All, I am researching trailers for the new car. I need the trailer to be shorter than 5.5m overall. Was thinking single axle with the axles closer to
the back of the trailer.
What do you have? (Pics would be great)
Where did you get it?
Do you like it? How easy to get the car off and on, getting in and out of the car once it is on the trailer etc.....
If I can find someone that works I will buy it otherwise I will make my own.
whathaveidone
Threads: 98
Mood: Heading for 10.99
| posted on July 1st, 2013 at 07:24 PM |
Mine is a single axle with a 3m deck and a 1.5m drawbar. front wheels sit right up the front of the deck and rears sit just behind the trailer axle.
The car overhangs at the rear a bit. I could have put an extra meter on the back(just incase someone hits me)It is balanced well and tows really good.
3m ramps that slide up under the car make it easy to load.
Just dont do this!!!!!
Stanley
Threads: 270
| posted on July 1st, 2013 at 08:15 PM |
h
| posted on July 1st, 2013 at 10:16 PM |
der look what I did pa.. I did a no good thing I think.. DOoooooooohhhhhhhhhh!
Aussie Dubbin
Threads: 90
| posted on July 1st, 2013 at 11:34 PM |
Converting a boat trailer is an option
andrewmurphy
Threads: 22
| posted on July 2nd, 2013 at 07:04 AM |
Ouch!!!
modulus
A.k.a.: Peter Hill
Mood: modular
| posted on July 2nd, 2013 at 08:27 AM |
Have a look at these threads:
http://forums.aussieveedubbers.com/viewtopic.php?tid=100220&page=1#pid936557
http://forums.aussieveedubbers.com/viewtopic.php?tid=84555&page=1#pid788711
http://forums.aussieveedubbers.com/viewtopic.php?tid=98222&page=1#pid916622
hth
andrewmurphy
Threads: 22
| posted on July 2nd, 2013 at 10:27 AM |
Thanks for those links.
humpty
Threads: 139
Mood: Totally boosted!
| posted on July 2nd, 2013 at 02:44 PM |
Here's some old pics of the one I built.... I rebuilt an old trailer, extended it slightly, but the total length is similar to Ben's.... Mine is a
broken back design with a 2100mm draw bar and 1800 long ramps..... The cable braked axle sits right under the 'B' pillar of the car and the balance
is perfect with 70kg on the tow ball... The total trailer weight is just under 350kg.
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
| posted on July 2nd, 2013 at 08:45 PM |
Good to see my old trailer doing well Ben, a few changes since I had it but still a good trailer
whathaveidone
Threads: 98
| posted on July 2nd, 2013 at 08:46 PM |
Wally, you, Craig them me.
dragvw2180
Threads: 33
| posted on July 5th, 2013 at 02:51 AM |
The best open trailer I ever owned was the one I hauled with my Oldsmobile Toranado . It was a very light 4 wheel that was very low and built so it
did not need ramps to load/unload the car. It did not use axles but instead used rear spindle and hub assemblies from the rear of a VW Rabbit bolted
into a box frame . The stock bearings never gave a problem and were cheap . It used the Rabbit wheels and tires also ,I liked it because tires were
cheap and had 4 tires in case of a flat . The trailer was so light that I never needed brakes on it on a panic stop and yet towed well. If I can find
some pics I will post them. Mike McCarthy
