| [ Total Views: 2900 | Total Replies: 14 | Thread Id: 102651 ] |
RodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
| posted on July 4th, 2013 at 08:08 PM |
NEW 2276cc turn key engine 172HP
I have a new 2276 cc engine here that is 100% brand new and is an identical duplicate of the new engine in my own beetle . This engine has been tuned
@ 137 HP on a chassis dyno and has almost 200 ft/lb of torque . This is a complete turn key deal and will be supplied with the exact same jets and a
copy of the dyno report . Everything on this engine is 100% brand new apart from the low milage rebuilt 48 mm dellorto carbs ;
Magnesium case opened and decked
82 mm Cromoly forged 8 dowelled chevy jnl crank
Forged moly H beam 5.4" rods with ARP bolts
Moly lightened flywheel
Moly HD gland nut/washer
Engle FK 43 camshaft
Scat solid lifters
Scat 1.4 pro rockers
Manton .035 moly pushrods
Stainless windage tubes
CNC round port heads , 42 x 37.5 stainless valves
Scat stainless valve covers with int. tabs
Scat crank gear kit
Scat oil booster kit
CB in/out 26mm oil pump
AA piston/barrel kit
All new black tinware
Welded balanced fan
55 amp int. reg. alternator
Billet Alt. pulley
CB Magnaspark ign. kit
Jaycee billet pulley
Geers billet oil filter
Ceramic A1 1 5/8 sidewinder
Dual 48 mm tri jets
CB hex bar linkage
Match ported off-set intakes
External oil filter adapter
Billet adapter bracket
Kennedy pressure plate
Kennedy HD disc
This engine in my own 76 bug , 17" wheels and .82 top gear can be driven @ 50 km/h in 4th gear , and is capable of 160 km/h in 3rd gear . This is the
best engine combo I have ever built and can be test driven in my car . This engine is ready to go and can be shipped Aust wide via Toll Express if
necessary . The compression is @ 9.08:1 and is priced @ $ 9400 . This is located in Wollongong NSW , ROD , 02-42729920 .
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
cnfabo
Threads: 140
| posted on July 4th, 2013 at 10:13 PM |
Rod loves that engine he said the torque is unbaleivable
Allbones
Threads: 58
| posted on July 5th, 2013 at 09:59 AM |
Mark Herbert was a massive fan of this size engine too, the Quaife diff video (link below) is him with his 2276. Isnt this the largest size engine you
can get with out having to cut the tin ware aswell?
http://www.youtube.com/watch?feature=player_embedded&v=ZvP9Pe0a9DY
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on July 5th, 2013 at 04:39 PM |
posted by cnfabo
Great price too.........another engine builder would charge that $$ for a 92hp 1916
smith64
Threads: 2
| posted on July 14th, 2013 at 11:41 AM |
Hey Rod,
I am a friend of Humpty and Paul and they rekon your motor is pretty dam good.
Have you sold it yet?
Gav.
mat54
Threads: 77
Mood: cruisinnn
| posted on July 14th, 2013 at 04:13 PM |
Gav
If youre serious i would suggest giving rod a call...;-)
Steff
lovinbronx
Threads: 12
| posted on July 15th, 2013 at 10:17 AM |
Would love to have this combo in my 63 beetle
RodPenrose
Threads: 330
| posted on July 21st, 2013 at 07:02 PM |
Here are some pic's of the engine , ROD.
| Error |
| Error |
| Error |
RodPenrose
Threads: 330
| posted on July 21st, 2013 at 07:04 PM |
The engine has a clutch supplied , however I need to know early or late thrust bearing first , ROD .
| Error |
| Error |
DakDak67
Threads: 15
| posted on July 22nd, 2013 at 04:07 PM |
Does this make 172 HP Rod ? Shit, I've gotta know how you do that !! Mines about 40 short!
Craig Torrens
Threads: 347
| posted on July 22nd, 2013 at 05:50 PM |
posted by RodPenrose
This engine has been tuned @ 137 HP on a chassis dyno and has almost 200 ft/lb of torque
SuperOwen
Threads: 67
| posted on July 22nd, 2013 at 07:25 PM |
137hp was at the wheels Craig. I've driven this same motor in rod's 76 beetle, it really is a great combo, goes hard but it's as well behaved as a
stocker.
Craig Torrens
Threads: 347
| posted on July 22nd, 2013 at 08:26 PM |
Yep, that's exactly the point I was making to DakDak67..... its 137hp atw (chassis dyno) as stated by Rod in the original post
turboty
Threads: 26
Mood: good
| posted on July 22nd, 2013 at 08:55 PM |
whats the trade in on a 1600tp worth lol??
just because its a kit car... doesnt mean its not a vw!
DakDak67
Threads: 15
| posted on July 23rd, 2013 at 10:43 AM |
Cool, sounds tough. They're nice figures for a 2276 that will last.
