[ Total Views: 1648 | Total Replies: 13 | Thread Id: 102652 ]
Author: Subject:  Staging brake
MemberStanley
Threads: 270
posted on July 4th, 2013 at 08:35 PM
Staging brake
I'm looking at installing a staging brake prior to Jambo and Warwick for the new engine. The CNC brakes look good but are a bit exy does anyone have any other options? Feel free to show your set up
MemberSuperOwen
Threads: 67
posted on July 4th, 2013 at 09:47 PM
Have you already used the handbrake with the ratchet disabled? Cheapest method obviously.
Memberdragvw2180
Threads: 33
posted on July 5th, 2013 at 02:28 AM
Find a master clyinder and caliper from a motorcycle and build your own stand alone setup with a linelock installed on it . Mike McCarthy
Member1916baja
Threads: 176
posted on July 5th, 2013 at 05:53 AM
Rod has them for about 75 bucks.
http://i432.photobucket.com/albums/qq43/1916baja/BigAssWing22.jpg
MemberFROSTY
Threads: 65
posted on July 5th, 2013 at 05:59 AM
I'm needing the same as I don't have a handbrake. I did see rods but haven't called him yet 75 bucks that fits the budget.
MemberStanley
Threads: 270
posted on July 5th, 2013 at 09:25 AM
I use the hand brake now for staging but i'm chasing something to lock front wheels for burnout.
Memberhypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
yes.gif posted on July 5th, 2013 at 10:20 AM
We have found using a steering/turning brake is quite effective for use as a staging brake ( both Chris Bolton and Ben Ford use them ) and as it is a dual circuit unit , it can also be plumbed to push the lever in the opposite direction also to lock the front wheels for burnout purposes , if you dont want to install an electric line locker . It would have to be plumbed from a single circuit master cylinder as it only has one inlet fitting and 2 outlet fittings
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on July 5th, 2013 at 12:57 PM
Been using the good old handbrake method for years, but I have upgraded to a steering brake on the new POS pan.... Mine is a total rip off of how Ben's setup is rigged on the VWMA car.... Works pretty well for him from what I have seen.... And I kinda like the idea of having some control over the brakes where you can control the amount of lock you put on.
FUCH your early!
http://www.noh2o.org/
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on July 5th, 2013 at 01:51 PM
My Drawing not good enough for you:(:(:(
MemberFROSTY
Threads: 65
posted on July 5th, 2013 at 05:27 PM
Thanks Wayne, I am only running a single with back brakes only so that will be perfect.
Jason
MemberStanley
Threads: 270
posted on July 5th, 2013 at 07:38 PM
Yes....it was sooooo good it made me hungry for more info. :lol:
MemberStanley
Threads: 270
posted on July 5th, 2013 at 07:43 PM
Thanks Wayne...I'm running a duel circuit MC so would look at plumbing somthing into the front wheels.
MemberFROSTY
Threads: 65
posted on July 9th, 2013 at 07:59 PM
Hey Stanley, Rod Penrose express mailed two of them today should be here tomorrow. Ill bring yours up to the tnt.
Thanks for sending it out so quick Rod!!
Membertypethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
posted on July 9th, 2013 at 08:17 PM
I brought a ksport hydraulic handbrake off eBay, works well
[ Queries: 40 ] [ PHP: 13.2% - SQL: 86.8% ]
