| [ Total Views: 1436 | Total Replies: 6 | Thread Id: 102892 ] |
Abbeyborg
Threads: 9
| posted on July 27th, 2013 at 02:32 PM |
Lowering with dropspindles problems
So I just brought 2 145r15 tires for my 70 bug (lowering) and a person just told me that I will still rub while using drop spindles. If true I have
just wasted $200+
matberry
| posted on July 27th, 2013 at 03:24 PM |
Depends on wheels, shocks, beam, brakes and height, but yeah, may still rub on a bigger bumps whilst turning
bitemeoz
Threads: 38
Theme: UltimaBB Vintage
Mood: Antsy
| posted on July 27th, 2013 at 05:19 PM |
I have 135s and there is no chance of rubbing with drop spindles. It's has a good inch at least of room.
Paulc1964au
| posted on July 27th, 2013 at 06:02 PM |
Well unless u have 135 tyres yes they will rub, in the end I installed a two inch narrowed beam and end of story
lohoon
Threads: 67
| posted on July 27th, 2013 at 08:58 PM |
Yep, just done the exercise. Put dropped spindles in. Let car down off the jack, tyre was hitting the guard.
empi
A.k.a.: Empstar
Mood: thunderous
| posted on July 28th, 2013 at 11:05 AM |
should a got 135s
"If at first you don't succeed, skydiving is not for you." - Anonymous
vwo60
Threads: 71
Mood: good
| posted on July 28th, 2013 at 03:56 PM |
you really need to have wheels with a different ET, if the dropped spindles add 20mm a side then the wheel would have to have a increase of +20mm ET
to put your tyre back into its original position. ball joint spindles should only increase the track by 6mm a side, link pin spindles about 20mm a
side.
