[ Total Views: 557 | Total Replies: 6 | Thread Id: 102900 ]
Author: Subject:  WTD Engine Hatch and suround Brisbane Area
Member68BUS
Threads: 19
Mood: Berwildered
posted on July 28th, 2013 at 03:11 PM
Does anyone have an Engine Hatch and surround available in the greater Brisbane Area?
1966 Aussie 11 Window
Memberbushed
Threads: 66
posted on July 29th, 2013 at 09:21 AM
yes, but what for, 74, 73 here
Member68BUS
Threads: 19
Mood: Berwildered
posted on July 29th, 2013 at 09:56 AM
Does not matter.
I want the lid and the surround supports to fit it into the back of a splitty bus.
My new motor has a turbo fitted up top and a side draft carby. Both of which sit higher than the current fly wheel tinware but also higher than the sheet metal of the rear parcel shelf.
I plan to put in a 50mm raised box and then sit the engine hatch and surround onto that. To give me access to work on them as well as fit them.
If that makes sense.
I would be very interested in a 73 or 74 if you have them. Especially if the surrounding metal is available too.
It just makes it easier for mt to fit and get air tight as well as being able to buy an off the shelf rubber seal for the lid for noise and fumes.
Memberbushed
Threads: 66
posted on July 29th, 2013 at 10:03 AM
yepp, surrounds are all very gd
may trade some other bay bits esp slider rubber?
am hme 2 day if you want to get it or cut till late m8
04212 86423
Memberbushed
Threads: 66
posted on July 29th, 2013 at 10:04 AM
i need a 12vlt 1600 starter btw
Member68BUS
Threads: 19
Mood: Berwildered
posted on July 29th, 2013 at 10:23 AM
Thanks Bernie.
I will give you a call later.
And you cleaned me out of Bay stuff the other day. The few items you didn't take I put on ebay to get rid of.
Not sure I have anything left now.
Apart from those wheels you saw out the back of my house.
If I can think of anything else I have kicking about I will let you know.
Cheers,
Brad.
Memberbushed
Threads: 66
posted on July 31st, 2013 at 01:07 PM
sorted? whole back panel avil if u want Brad
B
