[ Total Views: 782 | Total Replies: 5 | Thread Id: 102912 ] |
PorscheKombi
posted on July 29th, 2013 at 01:00 PM |
Performance - J tubes over heatexchangers
So how much difference in performance does this make!!!
I have a Porsche 911 engine in my bus running a fully stainless custom exhaust. Two 3-in-1 headers into a back box. I am weighing up replacing the
headers with heat exchangers.
the reason, the bus is back in the uk where some heat would be useful for the majority of the year. I have a propex gas heater that i have plumbed
into the stock Y pipe, but due to the sheer length of the ducting system there is no back pressure left in the system so heating is pretty
non-exsistent. My only feasbile option is to possibly source an inline fan to boost, or put heatexchangers back in.
now the bus isnt used for track or 1/4mile action, but I was wondering what the performance difference would be between running stock heatexchangers
and effectively Jtubes???
maybe some of you drag racing guys would be best positioned to know?
NaFe
68BUS
Threads: 19
Mood: Berwildered
posted on July 29th, 2013 at 01:17 PM |
Just a thought. A lot of guys reckon that a stock heater setup does squat anyway without a fan as the air has cooled by the time it gets to the
front.
Maybe try the fan in line first and see from there if you still need extra warmth.
You can also put in heated seat pads but that involved removing the covers which would be about as much work as fitting the exchangers.
1966 Aussie 11 Window
matberry
posted on July 29th, 2013 at 01:39 PM |
For the record, I think stock late bus heaters work ok, just most are incomplete in some manner, as for Mr Porschekombi, stock 911 heat exchangers
flow awesome, they are probably very similar or the same as what you have presently, 2x 3-1 with sheet metal casing over them. I don't see the
problem. It takes an absolute awesome system to out perform the stock Porsche system.
as mentioned tho, an inline fan is a symple addition.
[EDIT] just noticed you said yours is presently S/S so there's a difference, but the stock merge is beautiful.
PorscheKombi
posted on July 29th, 2013 at 02:00 PM |
the exhaust will be restricted to a certain amount as it will be going through the fins as opposed to the larger exhaust manifolds. i would also have
to buy the other components like a blower and piping etc. it would end up being a bit of a custom jobby. i'm thinking using the type 4 hot air
heater blower supplying the flow. this could then be adjusted by a potentiometer...i may be able to use a VW headlight switch, utilizing the dimmer
for the instrument cluster back light...or simply an on off switch lol
matberry
posted on July 29th, 2013 at 06:24 PM |
The early heater boxes I have experience with are pipes inside a tin housing so maybe you can get an earlier set that are less restrictive? I thinkr
h/light dimmer would burn out with the load of a fan on it, maybe you can get a high wattage potentiometer....??
68AutoBug
posted on July 29th, 2013 at 10:36 PM |
Quote: | Originally
posted by PorscheKombi
NaFe
I don't know anything about Porsches but J pipes and VW heat exchangers would be the same... and You can get larger heat exchangers for larger
engine in the UK.. USA..
I believe having a heater is worth the few horsepower if any You lose, is well worth it...lol..
warm Feet is worth a lot..lol being warm all over is even better.. lol
