| [ Total Views: 1374 | Total Replies: 5 | Thread Id: 103539 ] |
Marco_VESS
| posted on September 23rd, 2013 at 11:41 AM |
Child seat anchor points
Has anyone had child seat anchor points installed in a bug? If so, what's involved and roughly what did it cost? ('71 Super in case it makes a
difference...)
Marco
1971 Super Beetle "Olivia" - Moss Green
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on September 23rd, 2013 at 11:59 AM |
from previous threads
http://forums.aussieveedubbers.com/viewtopic.php?tid=95743&page=1#pid891039
http://forums.aussieveedubbers.com/viewtopic.php?tid=72669&page=1#pid677736
http://forums.aussieveedubbers.com/viewtopic.php?tid=58761&page=1#pid557590
http://forums.aussieveedubbers.com/viewtopic.php?tid=57487&page=1#pid544990
http://forums.aussieveedubbers.com/viewtopic.php?tid=47707&page=1#pid445432
http://forums.aussieveedubbers.com/viewtopic.php?tid=9555&page=1#pid77388
Marco_VESS
| posted on September 23rd, 2013 at 04:01 PM |
Thank you - I did a search but found nothing
barls
Threads: 296
| posted on September 23rd, 2013 at 04:44 PM |
its all about the right term and changing the drop box from this week to from the beginning.
pfillery
| posted on September 24th, 2013 at 12:51 PM |
posted by Marco_VESS
difference...)
Marco
To directly answer your question, I've seen them fitted in a couple of places, either just under the rear window, bolted through underneath the
grilles (technically a lot more involved to do) or in the bottom of the luggage area behind the rear seat (easier). Really depends on your local laws.
In Qld you can fit them yourself as long as you do it according to regs and get it inspected and plated. IE you don't need to "have it fitted by a
qualified person". You need to use a certain size bolt and a plate with welded nut, riveted to the body etc.
My ones I had done in the kombi cost $110 for a mobile certifier to come out and inspect and pass them and a back seat install as well. That was
cheaper than taking it somewhere because a lot of them count anchor points and seats as 2 seperate mods and want $180 for the plate.
Like I said, may be different in other states.
Cost wise for mine it took half an hour for me to fit 3 of them, the captive nut mounting plates were free (went to a mod place and they just gave
them to me), high tensile bolts were $3.50 the pack at Bunnings, the child anchor attachment was $9 at the local K-mart and a couple of rivets,
washers etc I already had. Easy to do, if you can drill a hole you can fit one.
bnicho
A.k.a.: Brett Nicholson
Threads: 55
Mood: Usually Cranky!
| posted on October 10th, 2013 at 04:53 PM |
I put mine through the firewall below the grille and above the fan shroud. Not difficult to do and they still clear the 6x9 speaker boxes I have in
the rear luggage area when in use.
Cheers,
Brett Nicholson
Melbourne, Victoria
1974 VW Superbug L - Olive
1971 Morris Mini Moke - Mopoke
1966 Austin Mini - Audrey
1965 Morris Mini Traveller - Trixie
2007 Land Rover Freelander 2
2009 Nissan Pathfinder
