[ Total Views: 688 | Total Replies: 4 | Thread Id: 103602 ]
Author: Subject:  removing 66 beetle steering column
Memberbrujo
Threads: 6
posted on September 29th, 2013 at 06:03 PM
I want to take my steering column out so i can remove the body of my 66 beetle. Do i have to take the steering wheel off? -if so what else- i have removed the petrol tank to undo the front bolts-=
Membergrumble
Mood: happy all the time
posted on September 29th, 2013 at 06:39 PM
Undo the flexible coupling at the steering box,the column should then slide up enough to lift the body.
Memberpsimitar
Threads: 148
posted on September 30th, 2013 at 06:21 PM
If the couplers 2 bolts to the steering shaft coupling are removed then body should just lift straight up. If in doubt tho pull the steering wheel up and use a mole grip on the steering shaft to keep it raised outta the way :)
Memberbrujo
Threads: 6
posted on September 30th, 2013 at 08:55 PM
is it hard to completely remove the steering wheel and shaft because i am selling the body and keeping the parts?
Membergrumble
posted on October 1st, 2013 at 04:32 PM
No it isn't hard,undo the flange at the top of the coupling,release the wires for the horn and blinker switch undo the 2 bolts on the column bracket and pull the column upwards and it will slip out of the rubber seal.
