[ Total Views: 1491 | Total Replies: 11 | Thread Id: 103796 ]
Author: Subject:  Buying advice
MemberAlexanderbeetle
Threads: 3
posted on October 15th, 2013 at 07:08 PM
Buying advice
Been offered a 71 Sbug, little bit of surface rust above gutter near rear, but otherwise solid body and floor, interior likewise is mainly good apart from around rear window luggage area, 1600 is running fine but needs a new ignition barrell as is "a bit touchy". Looks like a solid car and looks like it's mine for 2k, I know it's hard to judge sight unseen but what do people think, I'm leaning towards a yes!
posted on October 15th, 2013 at 07:16 PM
Rust around the rear window above the gutter "can" be the beginning of a major rust out break
Supers suffer badly for rust in that spot.
Also check for rust in the floorpan and near the bottom door hinges in the A pillars
Check for steering wheel shimmy at about 80kms / hr or clunks in the steering
Check for endplay in the motor
For $2k - that is a fair price to pay for a super needing a bit of work
But if it has a good healthy motor you have half your money back already
Threads: 3
posted on October 15th, 2013 at 07:49 PM
Couple of pics
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on October 15th, 2013 at 08:04 PM
The ouch to the rust in that spot is that it all comes from the inside, and often only a quarter of it can be seen from the outside. Looks like a solid bug otherwise. If it has a good strong engine and other mechanicals are solid, it is worth it for sure.
MemberAA003
A.k.a.: Phill
Threads: 39
posted on October 16th, 2013 at 06:37 AM
What's with the engine lid?
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!:lol:
posted on October 16th, 2013 at 06:44 AM
There is a fair amount of rust in that C pillar. Will definitely need repairs.
Engine lid should be a 4 slot.
Can cause overheating issues.
They are readily available for $50 or so.
Again. If it has a good motor and mechanicals it is worth the money. If you know someone who can weld - even more so.
MemberAA003
A.k.a.: Phill
Threads: 39
posted on October 16th, 2013 at 09:49 AM
Engine lid should be a 2 slot.
(But 4 slot are better.)
Threads: 3
posted on October 16th, 2013 at 08:08 PM
Didn't even notice the lack of slots In engine lid, might be an opportunity for a bit of customisation? Yeah like a couple have said that rust is my biggest concern. Got a mate who's a panel beater by trade and handy with welder, might take him to have a look. Thanks for the feedback it's appreciated!
Memberphoenixdigital
Threads: 1
posted on October 25th, 2013 at 05:37 PM
Just a question to those commenting about this rust. What is the approx cost of repair of this ballpark?
I had my beetles rust removed about 12 years ago but rust is coming back in that spot. I'd like to potentially stop it in its tracks before it gets too bad.
posted on October 25th, 2013 at 05:59 PM
a lot.
It is coming from inside where they sprayed foam and holds moisture
To guarantee it is gone you would need to strip the car to bare metal and then get the car and dip it or media blast it
get it patched again - 12 years is bloody good for keeping rust out
Threads: 1
posted on October 25th, 2013 at 10:45 PM
a lot.
So obviously the cost would depend on theextent of the damage. But what is the range of costs for things like this?
$200?
$2000?
$20000?
ie something like this fix cost?
http://forums.aussieveedubbers.com/viewtopic.php?action=attachment&tid=10...
posted on October 26th, 2013 at 06:46 AM
Somewhere between the $2,000 and the $20,000 :smilegrin:
have a look at this post and you can see the work involved in fixing that area
http://www.thesamba.com/vw/forum/viewtopic.php?t=259211
$200......... that would cover the beer at the end of the job
$2000....... yes, but only that area and it may return. You would be patching/matching the paint
$20,000.... that would take it off the road and get it stripped and re sprayed. It would depend on how much rust was discovered after the strip
Have a look here at the amount of rust that was discovered once the body was stripped
http://forums.aussieveedubbers.com/viewtopic.php?tid=97264
A panel beater could cut and patch and not worry about matching the paint for maybe $1,000
If you want an expert job you will need to find a tradesman you can trust
They dont like working on old cars as it is hard to guarantee the rust wont come back and spoil the spray job
Maybe start a new thread and post some more pics
[ Queries: 40 ] [ PHP: 15.4% - SQL: 84.6% ]
