| [ Total Views: 594 | Total Replies: 5 | Thread Id: 104027 ] |
nils
Threads: 65
| posted on November 10th, 2013 at 09:05 AM |
thermostate o rings?
Anybody know what O rings go in these thermostats? As you can see, mine leaks
Quit calling rust patina
matberry
| posted on November 10th, 2013 at 09:40 AM |
They need rebuilding out-of-the-box. The O'ring will be pinched and the bore scored. Strip, tidy and reassemble. I use new O-rings from a generic
kit. one that fits that is hydrocarbon (oil) friendly
And I prefer to mount it up the other way, so dirt and water is'nt trying to get into the circlip etc
nils
Threads: 65
| posted on November 10th, 2013 at 10:48 AM |
Think thats where my problems started. Its always had a slight leak, so thought a rebuild with viton rings would be the go, got a lot worse I guess I got the wrong size. will feret around in some of the GJ
kits at work.
vwo60
Threads: 71
Mood: good
| posted on November 10th, 2013 at 11:19 AM |
You will need to measure the depth and width of the oring groove, there is a chart that will give you the correct section, work out the ID, use a
Viton oring as suggested, I have two of these and they have never leaked, just lucky I suppose.
nils
Threads: 65
| posted on November 11th, 2013 at 07:20 AM |
good advice I will look into that, Cheers
wild baja
Threads: 3
| posted on November 11th, 2013 at 11:35 AM |
I would expect 60-70 Duro Nitrile Rubber O rings would be the go.
