| [ Total Views: 1624 | Total Replies: 3 | Thread Id: 104190 ] |
Bone
Threads: 43
| posted on November 26th, 2013 at 10:55 PM |
EJ22 gen 1 vs gen 2 engine.
Could someone tell me the differences between the ej22 gen 1 engine and the ej22 gen 2? I know the engine loom and manifold are different but what
are the improvements fron gen 1 to gen 2? Does the gen 2 engine have more hp or better fuel economy ect ect?
Joel
| posted on November 27th, 2013 at 06:23 AM |
The oil control rings changed in early gen1 engines but aside from that there were no real changes till late 90s EJ22s to the actual engine itself, it
was all the bolt on crap that changed, the new heads on 97 onwards are interference though so if the timing belt jumps or breaks you got bent
valves.
The Gen2 actually make less power with Australian models, not enough to notice though.
It was mainly the exhaust system, dropped power but raised torque.
90-94 gen 1 EJ22M 100kw/189Nm @6000rpm
95-96 gen 2 EJ22E 94kw/190Nm @ 4400rpm
97-98 gen 2 EJ22_ 98kw/193Nm @ 4400rpm
Bone
Threads: 43
| posted on November 27th, 2013 at 07:03 AM |
Thanks Joel, I didn't think there was anything major. I have a Gen 1 in my Baja and a mate is about to go Gen 2 in his buggy and noticed the
different shape manifold and engine loom (interchangeable I'm told).
Joel
| posted on November 27th, 2013 at 10:52 AM |
Its mainly just a few sensors that need swapping (knock,cam and crank) to make the engine match up with the loom.
rest is all in the manifold which can be swapped.
