| [ Total Views: 768 | Total Replies: 8 | Thread Id: 104193 ] |
london_mike
Threads: 2
posted on November 27th, 2013 at 10:05 AM |
Backup Lights
I've had by '71 standard for almost 5 years now and bought it with roadworthy, but just this week I took it in for another roadworthy and one of the
(many) things that came up was "reverse lights out" - so thinking it must be a simple wiring fix I took it home to take a look.
Here's what I saw:
Beetle Backup light. by michaelpickard, on Flickr
Now - to me it looks like there's a bulb (and holder?) missing - that spade connector is supposed to go somewhere - right?? So god knows how it
passed the original roadworthy! I also can't believe I've been driving it for so long without backup lights!!
So... my question is: am I right? Is there a bulb and holder missing? what needs to be done?
'71 Type I Standard 1300
Joel
| posted on November 27th, 2013 at 10:43 AM |
Your bug never had reverse lights, 71 was the last year that didnt.
They started for 72, trouble is the 68-71 lenses without reverse lights were never reproduced so most bugs got the reverse light style if they needed
replacements.
Originals would have been the same as this
Tell the mechanic to look up what the ADRs on the compliance plate, it will be missing the one calling for reverse lights.
That stray wire is just the ground wire.
The tab often breaks/rusts off.
The lights still work by the bolts to the body.
You can add them if you wish but you will need to add all the wiring and if the gearbox is original it wont have the switch on the nose cone, just a
blank bung screwed in.
london_mike
Threads: 2
| posted on November 27th, 2013 at 11:14 AM |
posted by Joel
Your bug never had reverse lights, 71 was the last year that didnt....
Oh wow. Thanks for this info and for getting back to me so soon. Saved hella work and $$.
I'll pass the message on to the mechanic.
Nice bug too BTW, just like mine.
Would be good to meet up and compare sometime.
Joel
| posted on November 27th, 2013 at 11:49 AM |
Wish we could but it's probably a Commodore bonnet these days.
I totalled that bug back in 1999.
hulbyw
Threads: 133
Mood: I'm OK, RU?
| posted on November 27th, 2013 at 07:40 PM |
You can buy repro non reversing light 68-71 lenses. I bought some a while ago for my '68. That would be the easiest fix. Just replace the lenses. You
can retrofit reversing lights, but you would need a gearbox switch, globe holders and globes plus the wiring.
Cheers........Wayne
london_mike
Threads: 2
| posted on November 27th, 2013 at 08:17 PM |
posted by hulbyw
Cheers........Wayne
Thanks. Once I get through this roadworthy I'll add that to my list of things to do!
68AutoBug
| posted on November 28th, 2013 at 03:16 PM |
Easiest way would be to go to a model toy shop and get a bottle of red tail lamp paint... and paint inside the bottom of both the lenses...
any light from the tail stop lamp bulb will shine thru..
or even acrylic red paint at a cheap shop... or red spray paint..?
PS: this is an ongoing problem with these lenses on 68-71 cars
london_mike
Threads: 2
| posted on November 28th, 2013 at 09:30 PM |
posted by 68AutoBug
But isn't it a reflector on the originals?
Joel
| posted on November 29th, 2013 at 08:58 AM |
No, the reflectors are in the bottom of the middle section.
VWheritage in the UK are now selling German ones but they are $80 each
Lee's option is the easiest.
