[ Total Views: 2055 | Total Replies: 12 | Thread Id: 104278 ]
Author: Subject:  944 alloy trailing arms
MemberJayess
Threads: 35
posted on December 3rd, 2013 at 03:58 PM
Could anyone who has done it pass on any tricks as to what they did to make them work? I have tons of hypo bug parts would be happy to swap parts for knowledge.
eg; do I need to make eccentric bolts for front trailing arm bush/bolts? That will give me adjustment, but is it necessary or will stock bug bushes and bolts work.
thanks
MemberSTIDUB
Over it.
Threads: 57
posted on December 3rd, 2013 at 04:04 PM
Germanlook forums / tech articles are your friend :)
MemberSides
A.k.a.: Dave Sidery
posted on December 3rd, 2013 at 04:56 PM
Be careful about which alloy arms... there's at least 3 different types of alloy arms and each have different offsets.
Spring plates can be tricky too due to different bolt patterns.
Stock Bug pivot bushes and bolts will work, but eccentrics will obviously give more adjustment/variability.
Where are you, and what bits do you have ?
My toys
MemberSides
A.k.a.: Dave Sidery
posted on December 3rd, 2013 at 04:58 PM
Oh - and something from germanlook that might help you is http://germanlook.net/html/tech/Tech13Porsche944PartNumbers.php
My toys
MemberJayess
Threads: 35
posted on December 3rd, 2013 at 11:58 PM
Cheers, Im running 85 turbo, and have most of it, mainly wondered about how they finally fit up as far as track goes , how much wider is it, hand brake set up, getting bearings.
Cheers for advice
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on December 4th, 2013 at 05:24 AM
Ask these two...they're both running them.
PAZZAN and 1303Steve
MemberJayess
Threads: 35
posted on December 4th, 2013 at 10:12 AM
posted on December 4th, 2013 at 01:51 PM
Don't buy bearings locally, they are much cheaper at Pelican parts.
I also have the special tool to remove and install them.
I'm running 86 non turbo arms, they gave me 46 mm increase in track per side at the bolt face.
Memberkarmann141
Threads: 48
posted on December 4th, 2013 at 07:05 PM
Wealth of information using Porsche parts on a VW
http://vdubengineering.com/technical/porsche-brake-conversions-2/
1961 K Ghia - Porsche 5 sp, EJ20T, Brembo's, Dble A arm susp
1974 L Bug - Porsche 944 brakes, Boxster 16's
1974 Bay Camper - EJ20, twin radiators, Boxster 16x7's
Half Beetle trailer with Boxster 16x7's
2011 Tiguan TDI 4Motion
2010 LR Discovery 4 TDV
MemberJayess
Threads: 35
posted on December 7th, 2013 at 10:06 AM
Cheers guys. will do. Hey Steve js , richard Hs mate with L bug turbo
posted on December 7th, 2013 at 02:44 PM
Hi js,
I knew it was you, your white bug is the one I sold to Richards friend in Kyogle.
If you need to use the 944 bearing tool let me know.
I think locally the 944 bearings are about $200 each but $57US from Pelican.
MemberJayess
Threads: 35
posted on December 10th, 2013 at 05:09 PM
Amazing its a small Vee Wee world, cheers re bearings, Pelican for sure, what calipers are you running on rear?
MemberJayess
Threads: 35
posted on December 10th, 2013 at 05:56 PM
I got all my brakes and suspension worked out and tuned, took it for 2 runs,1 on vid Ill send you,the other just a 5min blat but,everything was bedding in ,tight , aligned
and...I was stopped 700ms from home turning right and a taxi didnt see me???? and tore left rear guard and wheel almost off. I can fix it but I will sell it after a coat of paint.
He is dodging making a claim, I didnt have comp insurance.
So sticking with turbo L and looking for a splitty?? $30g budget any ideas?
[ Queries: 40 ] [ PHP: 27.4% - SQL: 72.6% ]
