| [ Total Views: 770 | Total Replies: 12 | Thread Id: 104319 ] |
davidr
| posted on December 8th, 2013 at 11:52 AM |
Swing axle Internals...??
Hey guys,
I scored a type 3 swing axle to do a conversion on my bus. One of the rubber boots was missing and some of the oil laying around looked a bit watery.
So I popped the side plate off yesterday and found this corrosion and small crack.
I believe the box hasn't been in a vehicle for some time but was apparently going fine up until then.
Wondering if anyone has some advise weather or not to put it in and see how it goes, or should I be looking at replacing some bits first.
Hope someone can help.
Thanks heaps.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on December 8th, 2013 at 12:44 PM |
Just give it a go
Might find other issues with shifting etc anyhow.... At least then if you go the fixing route, you can tend to any other issues in the one go
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on December 8th, 2013 at 12:57 PM |
I have another diff you can have if that helps....just let me know.
matberry
| posted on December 8th, 2013 at 01:09 PM |
mmm 3 people, 3 opinions. IMO if you run that it will DIE very quickly, if it isn't already. Not the crack in the side gear, not sure that it would
be a problem, but all that corosion will make short work of wrecking anything that is good, it's like filling your gearbox oil with sand paper!!!
Craig Torrens
Threads: 347
| posted on December 8th, 2013 at 02:30 PM |
I didn't give an opinion, just offered free parts
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on December 8th, 2013 at 03:26 PM |
It would be a shame to ruin a good gearbox [if it is a good gearbox?] for the sake of swapping diffs.
Craig has made a generous offer, why not do it properly?
davidr
| posted on December 8th, 2013 at 03:37 PM |
Thanks gents.
I was considering putting it in for a full rebuild at some stage anyway. Is it safe to say if I do a rebuild it comes back as good as new.?
Any suggestions of someone in or near Brisbane that could do it and approx. cost.?
Thanks again.
matberry
| posted on December 8th, 2013 at 05:23 PM |
See Dangerous on here
davidr
| posted on December 8th, 2013 at 05:42 PM |
Thanks Matt.
Craig, Greg.. I have never had anything to do with swing axle so have no idea. Swapping diffs, doing it properly ?
Is the dif something that can be just swapped over.?
Thanks.
HappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
| posted on December 8th, 2013 at 06:38 PM |
Dangerous is the man...he just did my swing-axle box for No.8 Beetle.
And he's a lot closer to you.
hellbugged
A.k.a.: Daimo Pell
| posted on December 8th, 2013 at 07:13 PM |
Oops, didnt see the corrosion
dangerous
Mood: 591
| posted on December 8th, 2013 at 08:50 PM |
Yeah that corrosion is ugly, as is the cracked washer.
The rust shows where the high tide mark is.
Both should be addressed before use.
Unfortunately I am booked out till mid March next year.
posted by westi
That's mad Alan.
vlad01
Mood: Side ways
| posted on December 12th, 2013 at 08:39 AM |
posted by matberry
the crown teeth will just shatter under load I reckon.
that box is stuffed. I would jut toss it. there might be some good bits in it but I doubt it, prolonged moisture will damage harden steel alloys
found in a box.
71 notchback,
