[ Total Views: 845 | Total Replies: 8 | Thread Id: 104926 ]
Author: Subject:  Super Diffs
MemberSuper1302
posted on February 1st, 2014 at 04:24 PM
Super Diffs
how good are 4 spider super diffs, this is fitted in a box I got from a mate who got it done at Dunhams. (Shimmo built).
question also, what are they like under racing conditions, drag or be it circuit.
posted on February 1st, 2014 at 05:20 PM
traction wise the same, just a lot stronger than 2 spider gear diffs
MemberBiX
Threads: 154
posted on February 2nd, 2014 at 06:03 PM
I ran/have one in my gear box. As steve said, no advantage in traction, but should make the box stronger. Combine with a heavy duty side plate and should hold the diff together longer. But if the engine is stock or close and your not flogging it, a super diff may not be needed.
Go hard or go home!!!!
Membercoletrickle
Threads: 34
posted on February 2nd, 2014 at 09:22 PM
I had the spidergears seize on their shafts due to burnouts,apparently with the extra cross shaft you loose some of the oiling holes i had dangerous redo the box and i coated everything inside withthe same coating you see on pistion skirts the diff copped it on the shafts,spider gears,the gear thing the fulcrum plates sit in and fulcrum plates.I've an easy 75 k on it now and no sign of nothing bad.The Grouch and Bluey both had issuses with the fulcrum plates and axle spades due to lack of oil(Both cars are low and are hiway haulers)The Grouch got coating on the spades and fulcrum plates,Bluey had modifcations to the diff by dangerous and coated fulcrum plates afaik no probs and matty is a burnout slut!Dave or matty can tell u about the mods,but i think that the coating is a good thing.I think Dave said that wheelspin the traction cause the spidergears to seize om the cross shafts.
MemberSuper1302
posted on February 3rd, 2014 at 02:54 PM
I should be right then, hardly any burnouts, should be good for circuit work then?
posted on February 3rd, 2014 at 03:15 PM
They can be modded for extra oiling holes, Dangerous did it with my Super Diff when he fitted it.
Membercoletrickle
Threads: 34
posted on February 3rd, 2014 at 08:27 PM
Just realised my reply is a little missleading,matty busted my superdiff doing burnouts,he had issues with his just doing sustained hi-speed on the hi way I think daimo's was the same cause but not 100% sure on that.sustained hi speed with out the oiling mods was the cause i belive but a call to dave would confirm that.The coating on thepeices i mentioned are justsome extra insurance,hope thats a bit clearer.
MemberSuper1302
posted on February 4th, 2014 at 09:56 AM
i'm not sure if the one i have is done, i think dunhams may have done it!
hope so. might have to ring to see what they actually do to them
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on February 4th, 2014 at 11:08 AM
I had one for more than 150,000k's...........no mods done to the diff and never had a problem :tu:
