| [ Total Views: 1503 | Total Replies: 14 | Thread Id: 105291 ] |
cnfabo
Threads: 140
posted on March 3rd, 2014 at 05:03 PM |
auto to manual conversion,shift rod question????? NOW SOLVED
H guys
I have just welded in the cutch cable tube and decided to put my manual shifter rod in the tunnel just to see if everything was OK and its 3" or so
to long..do I use the I auto one or have to shorten the manual one..
If I have to shorten the manual rod do I cut it the same length as the auto one???I have realised the shifter location is moved back....
Joel
| posted on March 3rd, 2014 at 05:35 PM |
Semi auto shift rods are different length to manual but there are also a couple of different length manual shift rods.
What year bug are we talking?
Around 73 the gearstick moved further back so the rods are shorter.
cb john
Threads: 6
| posted on March 3rd, 2014 at 05:55 PM |
posted by cnfabo
H guys
Before you cut the rod, measure the angle between the ends...from memory something around 17 degrees...
cnfabo
Threads: 140
| posted on March 3rd, 2014 at 06:16 PM |
My manual one came out of my 64 beetle and the pan I'm converting is a 68/69 unless it got changed under the 68/69 shell once upon a time......
grumble
Mood: happy all the time
| posted on March 3rd, 2014 at 06:28 PM |
posted by cnfabo
I should have a shift rod from an S bug if that may help. if you want to check lengths let me know by pm.
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on March 3rd, 2014 at 06:57 PM |
Use the shorter rod, cut the end off. Weld in a nut in the cut end of teh shift rod (like an M12 etc.)
Then, use a fully threaded m12 bolt, say 100mm long, weld the end of the cut shifter rod (or piece of tube) on the bolt head for the shift coupler.
Use another m12 nut as a lock nut, now you have a fully adjustable shift rod
(ô_!_/ô) (ô_!_/ô)
cnfabo
Threads: 140
| posted on March 3rd, 2014 at 08:01 PM |
posted by bajachris88
Or this is another option but I'd use weld in threaded bungs...but surely there is another rod to use....???
bajachris88
A.k.a.: Chris Leete
Threads: 534
| posted on March 3rd, 2014 at 09:24 PM |
I think mine was an m12 coupler from a hardware store... its for coupling cyclone rods (also called hooker rods). its like a 25mm long 12mm nut.
massaged it in with a hammer.
(ô_!_/ô) (ô_!_/ô)
cnfabo
Threads: 140
| posted on March 3rd, 2014 at 10:04 PM |
Gotcha,coupler hex,cheaper the weld on bungs...and I thought it was called booker rods,not hooker " must be on your mind,lol....." He he...
I can do this no worries....
But while we are on the subject and for further info for users,there must be a manual shift rod that bolts straight in.....
Anyone?????
grumble
| posted on March 4th, 2014 at 07:57 AM |
posted by grumble
posted by cnfabo
Joel
| posted on March 4th, 2014 at 08:42 AM |
posted by cnfabo
Well theres yer problem.
The 60s 6volt ones are a bit longer as the gearstick was further forward with a dogleg bend in it because of the heater control.
the 68-72 manual with the straight gearstick were the same length as what you need.
cnfabo
Threads: 140
| posted on March 4th, 2014 at 09:20 AM |
posted by Joel
posted by cnfabo
Thanks Joel,so I'm assuming they are not the same length as the auto one.or they are as the gearstick is in the same place??if so couldn't I use my
auto one...
So many questions,
Thanks guys
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on March 4th, 2014 at 09:31 AM |
Humpty should have one, he has everything else over there !
cnfabo
Threads: 140
| posted on March 4th, 2014 at 09:48 AM |
:| Quote: | Originally
posted by Craig Torrens
cnfabo
Threads: 140
| posted on March 5th, 2014 at 09:12 AM |
I got a shift rod out of a same model beetle or thereabouts.its about 10mm longer then the auto one and has a slightly different bend....
ShWeet azz
