[ Total Views: 1096 | Total Replies: 2 | Thread Id: 105451 ]
Author: Subject:  Speedo issues in my Fasty
MemberGTMac
A.k.a.: Andrew
Threads: 246
Mood: Always asleep
posted on March 17th, 2014 at 08:04 AM
Speedo getting stuck
Hi all, my speedo is getting stuck at various places randomly on the dial. Suburb cruising 40 sometimes 60km/h. Freeway at about 80 no higher. It was working perfectly despite the car being driven lately maybe once a month over the last 6 months (don't think that should effect it).
It happened after I replaced dash with a new one, took all gauges out and then replaced after. Cable is all good and fine at hub end. Cable runs via speed sensor as I'm running a Suby engine. Can't think what I've done wrong. Took gauge out and turned over with a battery drill with and without speed sensor, still getting stuck.
Any ideas?
1971 Type 3 Fasty - EJ20T
MemberCamo
A.k.a.: Kev
Threads: 209
posted on March 17th, 2014 at 08:44 AM
I also run cable to electronic speed sensor and had my needle jumping around a bit. For me, it was just the case that I had to much bend in my cable as I was trying to hide it. Gave it the simpler path and it sits rock solid now at correct speed.
Just my experience and 2c, Kev
posted on March 17th, 2014 at 10:22 AM
Hi Andrew
You could take it to St George instruments, talk to Barry 95470855
[ Queries: 40 ] [ PHP: 14.5% - SQL: 85.5% ]
