[ Total Views: 2957 | Total Replies: 11 | Thread Id: 105636 ]
Author: Subject:  Type 3 Dash pad reproduction
Membercruiser
Threads: 17
posted on April 1st, 2014 at 12:35 PM
This is a reproduction dash pad for a 1961 -73 VW Type 3 Right hand drive only. No passenger side handle included.
The moulds used to make these dash pads were produced directly from a very good original dash pad so this mould process captures every texture and detail of the original dash surface grain just the same as the real dash. The closed moulds also reproduce the back side shape of an original dash too.
The original VW dash gauge holes have a plastic ring that supports the circular shape and also locates the gauges when inserted. With this replica dash we actually use these original rings from old dashes and set them in the moulds so that they are now reused and moulded into the new replicas too.
There is some further reading and info here http://www.thesamba.com/vw/forum/viewtopic.php?t=475227&highlight=rhd+rep...
$550 inc gst
Made in Perth, Australia by http://www.fastacraft.com
https://www.facebook.com/Fastacraft
Any enquiries ph 0419 907 923
http://images.thesamba.com/vw/gallery/pix/1142942.jpg
http://images.thesamba.com/vw/gallery/pix/1142944.jpg
http://images.thesamba.com/vw/gallery/pix/1189289.jpg
Membercruiser
Threads: 17
posted on April 24th, 2014 at 11:43 PM
Just a bump.
We have shipped two more dashes in recent weeks, one to Sydney and one to South Africa.
If you are interested then step up as these may be a limited run. I need the old plastic gauge rings in exchange to make new ones though.
Member1500S
Threads: 73
posted on April 27th, 2014 at 06:36 PM
Have you thought about making the pad for the up to 1963 model (shape includes up to 1965 German S) as the pad shown is only from 1964 on??
Membercruiser
Threads: 17
posted on April 27th, 2014 at 08:55 PM
I could do this too although the market for that is even smaller than the one I have. All you need to do is send me your perfect original dash so I can make a mould from it??
Member1500S
Threads: 73
posted on April 27th, 2014 at 09:31 PM
Someone actually bought a perfect RHD early one on fleabay a few years back! That was the only perfect one seen for many years so at this stage, the only way seems to be having one re skinned by the look of it.
Membertype3disease
Threads: 105
Mood: Average
posted on April 27th, 2014 at 11:03 PM
Is it just the ends are different as they curve around to join the door padded trim?
I'd happily help with an ok one I have that the ends could be replicated off... And used withpart of the current mould?!?
http://www.dakdakcafe.com
Member1500S
Threads: 73
posted on April 28th, 2014 at 03:55 PM
That would be great if it could have the ends grafted on. I have a reasonable mid 60s one here as well as two end portions from the early one but it's one of those things which I haven't got around to doing. The re skinned one by a company here in Sydney hasn't turned out great although it's been on there for 12 years now. They couldn't be told anything about not sanding a radius onto the area where it meets the door trim!
Membercruiser
Threads: 17
posted on April 29th, 2014 at 09:19 PM
It is not possible to make any mods to the current moulds that could make the ends as an early car.
I imagine that this replica 64-70? dash will fit those early cars just fine, of course the ends are not a match to the doors but it should still look just fine and there are no cracks. I know it's not technically correct for an early car but these dashes will still make the interior a nicer place to be. It depends on how bad your cracks are and if you can bare to stare at them when this could be a reasonable option.
Memberbus914
Threads: 233
Mood: Could be worse
posted on May 1st, 2014 at 09:53 PM
Do you have any RHD 64-70 dashes ready to go?
MemberPfeffernuss
Threads: 16
Theme: UltimaBB Pro Charcoal
Mood: retrospective
posted on May 2nd, 2014 at 02:56 PM
wow! this is defiantly worth considering
Besser als in die hohle Hand geschissen.
'71 Type 3 Fastback
'08 WRX
'14 Golf Variant HL
Membercruiser
Threads: 17
posted on May 2nd, 2014 at 04:18 PM
No I don't have any stock yet. I would like to have one but I need those plastic rings from the gauges of an old dash so I can use them in the new dashes. Just send me a ring set and I can make a dash.
Membermax-veedubber
Threads: 9
posted on May 13th, 2014 at 05:23 PM
would you be able to make a type 34 ghia dash???
