[ Total Views: 1997 | Total Replies: 12 | Thread Id: 106068 ]
Author: Subject:  Rear hub removal
Memberthepie
Threads: 22
posted on May 15th, 2014 at 05:51 PM
Rear hub removal
Hi all , looking for help , advice , just removed the 36mm nut from rear hub,and trying to remove the hub , with not much luck it seem to be stuck !!! What's the best way to remove it without a puller ? Or the best place to buy or borrow one , I'm based in canberra
Cheers Dave
Memberbug68m
Threads: 15
posted on May 15th, 2014 at 09:17 PM
Put the nut back on but don't tighten all the way up leave about 1/2 a turn loose put the split pin back in so it won't come off and go for a good hard drive around the block and check to see if it has come loose good luck best way is with a puller
MemberAussie Dubbin
Threads: 90
posted on May 15th, 2014 at 10:40 PM
Are your shoes bound up?
posted on May 15th, 2014 at 10:55 PM
back the brake shoes OFF
MemberShuffs
Threads: 3
posted on May 16th, 2014 at 08:24 AM
I would say'THIS' also,or is not something simple,like the hand brake being on?
Memberthepie
Threads: 22
posted on May 16th, 2014 at 09:15 AM
Thanks for advice , brake adjusters backed right off & handbrake off , hubs roll freely , I'll have to invest in a puller I think , anyone know best place to get one ?
MemberSTIDUB
Over it.
Threads: 57
posted on May 16th, 2014 at 09:35 AM
nylon/rubber hammer, give it a few taps on opposing faces & a spray of your choice of lube wd40/inox/penetrene etc should get it...
Membervduboy
Threads: 41
Mood: Dying to get more buggy building time..
posted on May 18th, 2014 at 09:01 PM
Bolt the wheel back on and give it a few opposing boots, failing that puller would be better.
It will all be OK in the end, if it's not OK it's not the end!
posted on May 19th, 2014 at 07:28 AM
Yes as per above
Put the wheel back on but with 3 bolts and have it so it ratttles Make sure you have a good jack stand under the car and also a temporary jack as well
then use the wheel as a rattle to remove the brake drum rock from side to side
posted on May 19th, 2014 at 07:41 AM
Try using a piece of soft metal like brass against the end of the axle, then whack this with a hammer
Membervwo60
Threads: 71
Mood: good
posted on May 19th, 2014 at 10:32 AM
Beaware you can bunell the bearing if you hit the axel to hard, all the force is directed into the bearing, this is why a puller is the correct method, even a three jaw puller will work in most situations. you could hire one for a couple of hours
Memberthepie
Threads: 22
posted on May 19th, 2014 at 12:21 PM
Where would be best place to hire one from ?
Membervwo60
Threads: 71
Mood: good
posted on May 20th, 2014 at 01:32 PM
Call up a tool hire place, make sure you get one big enough, do not apply to much pressure on the od of the drum.
[ Queries: 40 ] [ PHP: 16.7% - SQL: 83.3% ]
