| [ Total Views: 699 | Total Replies: 7 | Thread Id: 106468 ] |
donn
Threads: 428
Mood: LAID BACK AND CONFUSED
| posted on June 28th, 2014 at 03:36 PM |
Roller pedal
Can anyone here tell me how the roller pedal is fitted that is for sale on the
"Buying, Selling & Swapping Parts " section
http://forums.aussieveedubbers.com/viewtopic.php?tid=106444
I have asked Brendan but he can't help and I think it may be what I'm after to make the accelerator pedal function better in the wench.
Don
rose
doin it for d girls
Threads: 308
Theme: UltimaBB Pro Red
Mood: always happy
| posted on June 28th, 2014 at 03:42 PM |
its held on by a nut on the shaft on a 50s bug
[img][/img]
modnrod
Threads: 50
Mood: Old School Volksies!
| posted on June 28th, 2014 at 04:13 PM |
Rollerskate wheel (if they still exist! ) and one of these
things.......
https://www.google.com.au/search?q=shaft+bolt&tbm=isch&tbo=u&sour...
........also works well.
grumble
Mood: happy all the time
| posted on June 28th, 2014 at 07:12 PM |
From memory the shaft had 2 flats on it similar to what is on the other end and a short threaded section,with a little bit of expertise you could
modify your present rod that way or work out the required angle and weld the piece on to the shaft.I remember the foot jumping off the pedal on rough
roads and cross country in our buggies so we fabricated a pedal on a hinge in front of the roller.
donn
Threads: 428
| posted on June 28th, 2014 at 07:26 PM |
Thanks for that fellas ( and lady ) at the moment it has what looks like a roller skate wheel on the rod with a standard dub foot plate hinged on the
floor with a curved plater riding on the wheel, I have managed to move the hinged foot plate over to the right a bit but now the curved plate rides
right on the edge of the roller. The trouble is that the accelerator and the brake pedal are so close together that at times I get the stop pedal and
the go pedal at the same time, makes for some exciting driving at times.
psimitar
Threads: 148
| posted on June 29th, 2014 at 10:47 PM |
50s Beetles used an accelerator shaft that the Roller pedal mounted directly on. It was bent in a dog leg fashion with the end threaded to accpet the
retaining nut for the Roller.
After that they went with a floor mounted pedal that used a rod to link the pedal to the shaft. This is the shaft with the flat end with the 5mm hole
in it.
Then they used a small roller that ran in a sloped ramp on the rear of the latest designed accelerator pedal. Again the accelerator rod was dog leg
shaped again but the dog leg was shorter and the small roller held on by a circlip.
Don't think the designed changed after that.
FROSTY
Threads: 65
| posted on June 30th, 2014 at 07:37 PM |
Hi There, these pedals came straight out of a 56 and into my drag car.
jason
| Error |
psimitar
Threads: 148
| posted on June 30th, 2014 at 10:20 PM |
posted by FROSTY
jason
Yea, my bad. After I posted I remembered it was an armature that bolted to the accelerator rod and not doglegged. That was the later small rollers
only. Tis what happens when you post just b4 bed. DOH!!!
