[ Total Views: 874 | Total Replies: 4 | Thread Id: 106825 ]
Author: Subject:  Pertronix ignitor cooking
Memberbinner
Threads: 210
Mood: want more grunt
posted on August 9th, 2014 at 03:44 PM
Hi, left my bus sitting for 2 weeks and came to start it but the batt was dead so I tried to jump start it with normal leads not thinking about my electronic ignition, it almost started but then just wouldnt run.... Have I cooked my pertronix ignition?
My coil is at about 3 ohms testing. How do you test the pertronix module?
Yes I have fuel and no fuses have blown in anything, it was running perfect prior to leaving it for two weeks so all I can think is I've blown my ignition.....next step I guess is to put points in and see .....
Cheers in advance
Ian
MemberAmpdub
Threads: 44
posted on August 9th, 2014 at 04:36 PM
I'm not an expert but i woudl not have thought so, the battery would have acted as some kind of shunt/resistor and as you said no fuses blown so does not sound like there could have been a surge. A bit of a mystery i suppose do as you were going to changin the points and see how you go. Always good to learn something.
Memberbinner
Threads: 210
posted on August 9th, 2014 at 06:25 PM
Well,I just tested the ignition unit as per online tests from pertronix and seems ok.......this sux ass.....
Memberbinner
Threads: 210
posted on August 12th, 2014 at 05:39 PM
Don't panic,I sorted it out this arvo.
posted on August 13th, 2014 at 03:15 PM
What was the problem??
loose wire??
I will now start My Beetle with Pertronics ignitor at least every 13 days so I don't have the same problem :lol::lol::lol::lol:
