| [ Total Views: 1949 | Total Replies: 25 | Thread Id: 106941 ] |
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
| posted on August 21st, 2014 at 06:52 PM |
Gearbox Grind Out... Help!!
Just need some guidance and help on how to grind out my gearbox!!
I'm putting a later model 1776 engine in my 1966 Beetle (standard - 1300).
I need as much help as i can get!!
I don't want to grind too far!!
Plenty of people have done it...
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on August 21st, 2014 at 07:29 PM |
Just put the engine in and turn it over by hand at the pulley with a bar and socket as you tighten up the four bolts gradually. (Keep it square to the
box)
The teeth on the flywheel will cut it easy.
Once the bolts have gone tight, remove engine and grind a little more off for clearance.
Don't be scared, it's fairly simple
Some pics here....
http://forums.aussieveedubbers.com/viewtopic.php?tid=38560&page=10
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 21st, 2014 at 07:42 PM |
I've been told thats a dodgy way of doing it, but if you have done it?
hellbugged
A.k.a.: Daimo Pell
| posted on August 21st, 2014 at 08:15 PM |
It's the most accurate cause it's cut with what's going in there.
It actually cuts it with a very nice finish
Yep done it too many times
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 21st, 2014 at 08:19 PM |
Ok. Thanks for the help.
I'll probably post pics when done...
hellbugged
A.k.a.: Daimo Pell
| posted on August 21st, 2014 at 08:28 PM |
Yeah post pics, always nice to hear the end results...forum needs more of that
be easiest to turn over if you took the spark plugs out
Just take care near the starter bush. You will need to source an "adapter" bush to run a 12 volt starter in there too
Check your pressure plate is correct for the early thrust bearing as well
Change the input shaft seal if it needs doing while the engine is out too
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 21st, 2014 at 08:31 PM |
Done the bush. The starter motor is in. The problem now is what to do with the 6V cold start relay...
Do you care if i post pics of the inside of my gearbox, and the pressure plate and get you to see if it will match??
You obviously have the experience...!!!
coletrickle
Threads: 34
| posted on August 21st, 2014 at 08:33 PM |
or you can use a factory vw 180mm 12v flywheel,,You may need to look at getting a custom 180mm pressure plate if you plan on making decent
power.I've got quite a few if you want to go that route and can't find one local,cheers
hellbugged
A.k.a.: Daimo Pell
| posted on August 21st, 2014 at 08:37 PM |
Ha hah was wondering if you still had them in stock col
pics are great!
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 21st, 2014 at 08:38 PM |
Col, is it the flywheels or pressure plates you have?
coletrickle
Threads: 34
| posted on August 21st, 2014 at 08:57 PM |
posted by adlbeetle66
The flywheels or the pressure plates?
flywheels,they came on the 71?and later 1300std bugs,what yours had orinally,and use a1200/40horse pp and disc but depending on the box you may need
to fit a running ring to the pp if its a lage box/throwout bearing.
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 21st, 2014 at 08:59 PM |
But is that gonna suit my 12 v starter?
Because i have a 6 volt engine that i took out, but i cant use that flywheel because ive now converted to 12v, and the teeth spacing is different...
| Error |
vlad01
Mood: Side ways
| posted on August 24th, 2014 at 09:36 PM |
posted by hellbugged
Thats how i did it with no internet or any vw resources back in the day. Worked a treat!
71 notchback,
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 27th, 2014 at 07:59 AM |
box)
Some pics here....
What do you grind it out further with?
Anything else you have to be aware of?
(shaft, T O bearing)
Joel
| posted on August 27th, 2014 at 10:43 AM |
the 70s 1300 flywheels with 180mm clutch just use regular 12 volt ring gear.
How come you're sticking with the 1200/1300 gearbox?
that is going to be awful on the highway with a 1776 and doing those sort of revs you if you have your original non vented decklid you are going to
get heat issues, (stand offs or holes behind the number plate fix that)
If you have a hard start relay you can just swap it out for a 12 volt relay, any 30-40amp relay will do the job.
hellbugged
A.k.a.: Daimo Pell
| posted on August 27th, 2014 at 12:11 PM |
Carbide burr or emery flapper wheel
Check your engine mounts too, change them if need be.
I think what col has would be an oring centre flywheel (so suit your later crank) with 180mm clutch but 6volt ring gear.
Anyhow, you've hot the hang of posting pics, so add them to here or your members ridè thread as you go
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 27th, 2014 at 04:15 PM |
Here is my flywheel...
I have a 12 v starter, and my whole car is now 12 v.
| Error |
| Error |
hellbugged
A.k.a.: Daimo Pell
| posted on August 27th, 2014 at 06:24 PM |
Cool
Any pics of the pressure plate you are going to use?
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 27th, 2014 at 06:32 PM |
Here...
| Error |
hellbugged
A.k.a.: Daimo Pell
| posted on August 27th, 2014 at 07:11 PM |
Yeah ok
That's incorrect for your current thrust bearing.
You will need a center ring added to that pressure plate
matberry
| posted on August 27th, 2014 at 08:15 PM |
And you need to check the crank and flywheel are compatible, you may have a 6 volt crank that will require a machining mod to the crank.
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 28th, 2014 at 03:52 PM |
Yeah ok
Thanks for that. Can you PM me or upload a pic of an example that i need to follow please?
1303Steve
| posted on August 28th, 2014 at 04:52 PM |
Be careful with filings they can catch fire easily and they are magnesium so water wont put them out.
I fitted a 228 flywheel in to my late single side plate box years ago, it just nipped up when the motor was fully tightened after I thought I had done
enough clearing, so I backed of the motor bolts and then started the motor and did the bolts up a bit at a time, rough but it worked.Steve
hellbugged
A.k.a.: Daimo Pell
| posted on August 30th, 2014 at 08:15 AM |
info here.......
http://shoptalkforums.com/viewtopic.php?f=11&t=117066&hilit=pressure+...
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on August 30th, 2014 at 08:21 AM |
Thanx. Will take a look later on.
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on October 3rd, 2014 at 03:38 PM |
FURTHER TO THIS THREAD CAN BE FOUND HERE:
http://forums.aussieveedubbers.com/viewtopic.php?tid=106947
