| [ Total Views: 581 | Total Replies: 8 | Thread Id: 106972 ] |
Trendy
Threads: 25
Mood: 😎
| posted on August 24th, 2014 at 02:15 PM |
Wanted: Pedal assembly bracket
I am missing a component of my brake assembly: Specifically the item in the picture. But in words its the bracket and bolt that reinforces the pedal
tube that goes into the tunnel. And is this piece critical to have. Where does one buys parts and if not who would like to sell me a few parts for my
60 bug.
| Error |
1960 Beetle sedan (Bubbles)
Trendy
Threads: 25
Mood: 😎
| posted on August 24th, 2014 at 02:17 PM |
pedal assembly bracket
Are more like this
| Error |
donn
Threads: 428
Mood: LAID BACK AND CONFUSED
| posted on August 24th, 2014 at 02:19 PM |
So before I go ratting through my box of "STUFF", is it the piece on the end far left or the piece that looks a bit like a plate with a "U" shape
cut out?
Trendy
Threads: 25
Mood: 😎
| posted on August 24th, 2014 at 02:40 PM |
bracket
A piece closest to your left foot on the clutch. It must hold the assembly in place before it goes into tunnel.... which would go all the way to the
passenger side. There is also a bracket to hold it all together on the passenger side. I have that side. Please refer to picture again. Circle red.
donn
Threads: 428
| posted on August 24th, 2014 at 02:44 PM |
gotcha, I must have been posting while you were doing the second post. I'm off to the parts bin to check ----------------->>>
56oval resto
Threads: 23
posted on August 24th, 2014 at 06:06 PM |
hi Trendy
Vic at Vicsbahn has this part available , NOS - $20 , Used - $10 + postage
give him a call 0428145889
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on August 25th, 2014 at 06:32 AM |
What year is your beetle?
Unless it's a 67, your pictures are for later pedal assembly and from memory, the highlighted piece is not used on the earlier models. It will just
have a rubber seal there that has 2 lugs that pop into the tunnel
I will check today
Trendy
Threads: 25
Mood: 😎
| posted on August 27th, 2014 at 05:35 PM |
copy thaT
maybe your . My bug is a 1960. It may just need that rubber part your on about. No big drama.
grumble
Mood: happy all the time
| posted on August 27th, 2014 at 08:00 PM |
Daimo is right ,these weren't used on early bugs just a dust/noise sealing rubber.
