[ Total Views: 574 | Total Replies: 1 | Thread Id: 107103 ]
Author: Subject:  1600Dp Spacers under cylinders??
Memberplimthing
Threads: 8
posted on September 6th, 2014 at 07:39 PM
My Beetle is quite loud, not overly loud, just louder than i would like, especially when i put the foot down. I bought a stainless twin gt exhaust which has no leaks. I'm just wandering if its detonating or something wierd to do with mixture, timing and compression. When i rebult engine i noticed there wasn't any shims/spacers under cylinders like there were on my kombi's 1641.
Would you say i need to strip and rebuild and check deck height and all that to be sure????? Or should i just perform compression test to see whats happening. What sort of figures would you be expecting for a stock 1600DP compression wise.
posted on September 7th, 2014 at 07:47 AM
you should have worked out the compression Ratio when assembling the engine checking deck height and combustion chamber size
doing a compression test will not tell you this only that you have the same compression in each cylinder
[ Queries: 40 ] [ PHP: 2.9% - SQL: 97.1% ]
