[ Total Views: 668 | Total Replies: 1 | Thread Id: 107630 ]
Author: Subject:  Fuel pump not working while cranking
Memberd3wy
Threads: 6
posted on November 13th, 2014 at 10:47 PM
Hi guys,
I've almost got my Type 3 on the road however I've got a peculiar issue related to fuel supply.
After rebuilding the carbs and replacing the fuel lines it took putting fuel in the carbs directly to fire up the car and similar has happened today when the car ran out of fuel on the side of the road to get it's blue slip.
Currently it seems like there is a lack of fuel while trying to crank, but when I do manage to get it kicked over if I keep the revs up for a moment the car will start. Once there is 'fuel in the system' the car stars pretty easily afterward (even after a day/cooling down).
So what seems to be the trouble is that the fuel pump doesn't operate at low revs/while cranking. But while the car running all is well. Tho my understanding of the pump is the pushrod moving operates it and I can't understand why a speed difference would change this.
Has anyone come across this before or have any other tips?
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on November 14th, 2014 at 08:44 AM
Check the length of the rod. It may be worn and as a result your not getting the pressure you need
the chaos project - click me
