[ Total Views: 1338 | Total Replies: 4 | Thread Id: 107744 ]
Author: Subject:  Spark plugs, dizzy.. my mistake!
MemberAfab
posted on November 25th, 2014 at 05:32 PM
Good Afternoon Everyone
After a nice rough day working on my 71 Superbug I managed to fix 90% of my original issues, whilst creating some new ones!
So I rewired most of the front, got my head lights working, indicator, etc etc
However, I changed over my dizzy cap and put on new leads and now all of a sudden she doesnt want to kick.
So I just want to double check I have the leads correct, before I call in more professional help!
I have attached a pic i found on the net which I believe is the correct order, but just wanted to double check...
Andrew
posted on November 25th, 2014 at 08:56 PM
yeah - but have a read here
http://www.vw-resource.com/misfiring.html
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on November 25th, 2014 at 10:48 PM
I was always told to use a wipe of 'Never seize' or 'Copper grease' on plug threads.
Memberragged
A.k.a.: David
Just ask if you need HELP!
Threads: 46
posted on November 26th, 2014 at 01:25 AM
The position of the cylinders is correct, but we can only assume that the distributor has been fitted correctly. So, Rotate the crankshaft pulley until the timing mark on the on the pulley is at the 12 o'clock position. It will also line up with the join in the crankcase. Have a look at where the rotor button is pointing. That is where the spark will go! At this point either number 1 or 3 cylinder is firing. Dave
MemberAfab
posted on November 26th, 2014 at 08:52 PM
Hi guys
Thanks for all your help, she fired over this morning with a little bit of playing around...
Andrew
[ Queries: 40 ] [ PHP: 13.0% - SQL: 87.0% ]
