[ Total Views: 1174 | Total Replies: 1 | Thread Id: 107838 ]
Author: Subject: [WTB - NSW] Autocraft engine cases
Membershesace
Threads: 1
posted on December 6th, 2014 at 03:22 PM
I am wanting to buy Autocraft engine case for 101.6mm bore size. I will consider other brands. Used or new.
Memberrhrnldi
Threads: 7
Mood: New Project Time
posted on December 15th, 2014 at 06:52 AM
i have the following parts....
Most are brand new and not used... have been on the shelf since the early 90's
Scat case 3 piece design New
910 pro series heads New
6 x 5"7" Carillo Rods resized by crankshaft eng. (used)
3 stage Autocraft oil pump and pressure relief (used but tested)
86.5 mm crank type 4 + porsche journal .. waiting for final grind. It is a raw early flanged scat forging... Final grind depends on use.. turbo or nat aspirated...
Make an offer if you wish.
thanks
[ Queries: 40 ] [ PHP: 3.0% - SQL: 97.0% ]
